03-15-2012, 09:15 AM   #16
Uh oh-- I just spent a whole lot of time considering converting directors' loupes as possible external OVFs and had cine crop factor tables on the brain. . . sorry for the misinformation. . .
Scott
03-21-2012, 03:32 PM   #17
wanderography's Avatar
Heres an image with a wideangle macro converter I got off ebay...
03-21-2012, 04:11 PM   #18
Kirill_est's Avatar
What were you focusing on? I know from personal experience these macro lenses unscrewed from wide angle converters are far from stellar but they certainly can be sharper than this.
03-21-2012, 04:34 PM   #19
I was focusing on the flower, that leaf thats blurred is actually pressed against the glass, I'm not your go to expert on macro photography lol i just had a wide angle converter come in and kinda stuck with the macro adapter till I get a step up ring and know what size I need... And I just walked into my patio and took this picture real quick... Not a fan of it really, my zoom goes wider and I have the SLR Magic 60mm toy coming in that can focus up close... And the threads seem sketch, a tad off, I was air plane mechanic and I know my bolts and threads and these are a tad off and feel like there causing stress on my lens which can lead to a stress crack so I wont be using it anymore...
03-28-2012, 01:31 PM   #20
The CS mount is different from C mount, with a shorter flange distance, and my understanding is that CS mount lenses are usually designed for 1/2" and smaller sensors, so vignetting can be a problem with the larger 1/2.3" sensor in the Q.
I looked up the flange distances - while the screw mount is the same for C and CS lenses, the flange distance is indeed different.
C Mount = 17.526 mm
CS Mount = 12.526 mm
a C Mount adapter with a CS lens will not be a viable combination.
here's a database of the flange distances for just about any lens mount Camera Mounts Sorted by Register
camera, converter, fish, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Wide angle converter turff Pentax SLR Lens Discussion 17 09-24-2010 02:32 PM
Cheap - Wide Angle Lens Converter cdurfor Pentax SLR Lens Discussion 7 02-23-2010 11:57 PM
SMC vs Adaptall-2 wide primes: any thoughts? gabriel_bc Pentax SLR Lens Discussion 2 10-05-2009 11:48 AM
Wide angle converter w/50mm f1.7 manishved Pentax SLR Lens Discussion 7 03-28-2009 06:58 AM
All times are GMT -7. The time now is 10:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
