04-03-2012, 12:38 AM   #1
What adapter should I buy for my Q?
In order to use my current AF pentax lens, I would appreciate if you guiys could advise what is the best Adapter for Q? While using adapter, is it possible to use AV mode? can i use track-in forcus? How about using old manual lenses?
Thank you in advance.
04-03-2012, 04:55 AM   #2
Hello magicshi. Welcome to the Q forum. Congratulations on getting the Q.
The best adapter seems to be the RJ one on ebay. Make sure you get the one with tripod and APERTURE RING. Aperture ring allows using newer Pentax lenses that lack aperture ring. Without this feature those lenses remain stopped down to the smallest opening- usually f16-22.
AV mode works fine with the adapter since we are basically using the lens in stop down metering. The lens will be manual focus. As far as I know the Q doesn't allow a manual focus lens to shoot when the preset distance is matched by the subject. The image stabilizer can not be used with adapted lenses. Hopefully this will change with firmware updates. The Q becomes a mighty long range tool using adapted lenses. Enjoy it.
thanks
barondla
04-03-2012, 07:20 AM   #3
QuoteOriginally posted by barondla Quote
thanks
barondla
Hi, Barondla,
Thanks for detailed explanation. It's sad to know SR doesn't work with adapted lenses, but still can use tripod.
In this case, I'll buy a RJ adapter from ebay. I may come back to ask you more questions later, hope you don't mind. Thank you for your reply. Have a nice day!
adapter, camera, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
How can I pay when I buy camera or accessory at BUY/SELL page? rlatjsrud Troubleshooting and Beginner Help 4 01-09-2012 09:54 AM
Should I buy this laptop to speed up my workflow or buy a new lens? crossover37 Pentax SLR Lens Discussion 26 09-24-2010 09:41 AM
Pentax 1.7 AF adapter.. where to buy and will it work with FA 300mm? Albert Siegel Pentax SLR Lens Discussion 7 05-20-2010 05:42 PM
Where to buy genuine screwmount adapter? ismaelg Pentax SLR Lens Discussion 10 02-06-2010 02:57 PM
anyone know where to buy SMC PENTAX-F AF Adapter 1.7x dr100hr Pentax Camera and Field Accessories 3 09-15-2007 07:05 AM
All times are GMT -7. The time now is 10:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
