04-04-2012, 03:54 AM   #1
Leaf shutter vs Electronic shutter?
Hello all,
Been looking into the settings of my newly arrived Q. I see there is an option to use the electronic shutter as a default overriding the leaf shutter built into the 01 standard prime. I see the electronic shutter goes up to 1/8000s whereas the leaf shutter is limited to 1/2000s. However, is there a reason to prefer the use of the leaf shutter over the electronic shutter?
In bright light, would you prefer using the electronic shutter at faster shutter speeds, or the leaf shutter with the ND filter activated?
Tx, Wim
04-04-2012, 06:13 AM   #2
Hi Wim,
I don't believe that the electronic shutter overrides the leaf shutter for the speed range covered by the leaf. I can't prove it, but I believe that the electronic shutter just takes over at 1/2000 and extends the range of shutter speeds. The menu setting just allows you to limit the camera to the leaf shutter, forcing you to use a smaller aperture and/or the integral ND filter on the Quality Line lenses for higher Ev scenes. I've set mine up so the electronic shutter is active so I don't have to remember all of that, and I haven't seen a downside, but I won't discount that there can be a quality difference that I haven't seen (or really looked for), so YMMV.
I'd be interested to see if others have noticed a difference or have any different observations about how the leaf/electronic shutter settings actually work.
Scott
04-04-2012, 10:35 AM   #3
Kirill_est's Avatar
Yes, that menu option seems misleading to me, I wish it allowed me to use the electronic shutter INSTEAD of the leaf shutter for noiseless photography.
04-09-2012, 03:11 PM - 1 Like   #4
Paolo.Bosetti's Avatar
I suppose that at lower speeds there's no reason to use the electronic shutter if you have a leaf one available, for the latter not suffers from rolling shutter artifacts. Conversely, above 1/2000s those artifacts become less evident, and of course leaf shutters cannot go that fast.
04-09-2012, 11:29 PM   #5
Thanks everyone. Things are a bit clearer to me now.
Wim
11-13-2012, 05:01 PM   #6
jpzk's Avatar
Reviving this thread:
So, in Custom, 13: Electronic Shutter ... what are the implications of choosing 1 (Disable) vs. 2 (Enable) ... I am too a bit confused about this particular option.
At this time, I have left it on 1 (Disable).
Another question: does this have anything to do when mounting a non-Q lens?
I mean, if I were to mount a non-Q lens via an adapter (something I will certainly acquire soon enough), would this option be involved?
Thanks.
JP
11-13-2012, 05:31 PM   #7
" I mean, if I were to mount a non-Q lens via an adapter (something I will certainly acquire soon enough), would this option be involved?"
No, in that case you are using the electronic shutter all the time. The Q has no mechanical shutter in the body.
Shawn
11-13-2012, 06:11 PM   #8
hnikesch's Avatar
QuoteOriginally posted by Kirill_est Quote
If you turn off the shutter sound the leaf shutter is quieter than the in focus peep at it's lowermost setting and that can be turned off also. Tool menu 1, 4th item down, (sound effects) 2nd page
Hans
11-14-2012, 04:33 PM   #9
Riv
QuoteOriginally posted by Shawn67 Quote
Shawn
Partly true, the Pentax adapter has a shutter built in to it. Not sure if any 3rd party adapters do, in that case your restricted to the electronic shutter.
camera, leaf, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, shutter
Dum leaf shutter lens question kenyee Pentax Medium Format 5 02-02-2011 03:42 PM
Any experience on Pentax 645 135mm f/4.0 LS -- Leaf Shutter hinman Pentax Medium Format 11 11-23-2010 05:15 PM
Thoughts on 90mm leaf shutter lens Isis Pentax Medium Format 4 09-21-2010 03:44 AM
K7 and the 75mm Leaf Shutter Lens HawaiianOnline Pentax Medium Format 4 09-20-2010 10:12 AM
Mirror vibration/Leaf shutter Lunaray Pentax Medium Format 10 06-02-2010 12:00 PM
All times are GMT -7. The time now is 04:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
