Originally posted by barondla Welcome to the forum felixkh. You are correct the Q is a very small camera. It won't take you long to get used to it ( menus are similar to your K5). Paolo.Bosetti is telling the truth- the Q will change your photography.
Don't forget to check the body and lens firmware. You want the newest one. It is easier to update the Q than past Pentax cameras.
Consider entering images in the compact camera contest in the compact camera forum. The Q is allowed.
thanks
barondla
Hi Barondla,
Thank you for your comments. I will play with the camera more to get used to it and after that will enter the compact camera contest in the forum.
May I know if the 02 standard lens is good to buy for general use?
