Originally posted by pghwarrior23 These are really interesting. I am wondering...once you put them on, can you easily take them off and not ruin the camera? It would be nice to change out once in awhile or know that I would be able to sell the camera in its original form when I decide to part with it.
Hi pghwarrior,
I contacted Aki-Asahi with just that question and got this response:
"Thanks for your inquiry.
1 As for the original cover, you can peel off slowly, then you can
remove very easily. The original skins are stuck with double coated
tapes on the camera body.
2 You could use (stick again) the original cover.
3 Our coverings will not work like that. Once you removed from the
camera you can not stick again."
However, I would imagine if you used double coated tape or something like "UGlu " to attach the skins, you should be able to switch them out and reinstall the original. I'm thinking of doing just that myself. . .
Scott
