Hi devorama,
I'd like to see the new lenses also, but I'm more interested in the tele zoom and the OEM K to Q adapter.
With the tele zoom, I should be able to shoot macros relatively effectively with achromatic diopters and flash since the lens would be a Quality Line lens with a leaf shutter (so it would eliminate the flash problems with adapted lenses), and the higher native magnification would make the diopters more effective. For this purpose, I could care less if the camera isn't pocketable, it will be quite a bit over 2 lbs lighter than any DSLR combo that would be effective for what I want to shoot.
The Pentax OEM K to Q adapter, if it delivers all that has been indicated, will also have the leaf shutter, so should eliminate the flash problems (slow sync speed for the electronic shutter, incompatibility with non-TTL external flash, and inconsistent performance with P-TTL external flash). The tripod foot would be convenient for some lenses, and hopefully, the release of this adapter would also be accompanied with a significant firmware update that would address the lack of ability to manually choose a FL for non Q system lens use with SR and the flash deficiencies previously mentioned.
It's "Spring" already. . .Q users need some of the promised love from Pentax. . .
Scott
