05-01-2012, 08:42 PM   #1
i_trax's Avatar
O-RC1 water proof remote control
did anyone had a chance to test this water proof remote with the Q?
Pentax Remote Control WP reviews - Pentax Camera Accessory Review Database
it suppose to have much better range than F.
It is weather sealed so how can you change battery ( can you)?
05-07-2012, 08:24 PM   #2
I don't think you can change the battery in it- which is sort of a bummer, but I've never had any of my remote control F's run dry.
05-10-2012, 05:46 AM   #3
i_trax's Avatar
thank you Adam,
yes, I never had to change battery in my F ( nearly 3 years old).
O-RC1 should be OK with the Q, one was just sold on AU eBay with black Q with assurance that they are happy with each other.
Zoom obviously will do nothing with Q, just wonder what Fn could possibly do
05-27-2012, 06:08 PM   #4
dmort's Avatar
I have the q and that remote. I'LLC try it out and report back.
The fn button may be for use with other Pentax point and shoots.
06-26-2012, 09:35 PM   #5
dmort's Avatar
I should have posted this about a month ago, but the waterproof remote works just fine with the q. Tried it this evening.
06-27-2012, 01:54 AM   #6
i_trax's Avatar
thank you dmort.
"Fn" does anything?
kind regards
jack
06-27-2012, 06:48 AM   #7
dmort's Avatar
THe Fn button doesn't do anything. However the focus button does work, you can autofocus remotely.
07-25-2012, 10:15 PM   #8
junototoro's Avatar
I used this remote for a couple of times. And now I can't find it ;'( have to buy a new one. The size is so tiny. I attached a lanyard to it too. I guess I'm just very disorganised.
Question - does the middle button focus and the top button release the shutter? Is it how it's supposed to be used? I wasn't really sure. Other cheap remotes on ebay only has one button to operate.
12-16-2012, 04:04 AM   #9
Short answer: no you can't
I bought one a few month ago. Now I believe the battery's dead already . So I tried to change it (basically sending it back for replacement would nearly cost its price, so I thought it'd be better to do it myself).
Unfortunately it's all glued and welded together. Once you remove the 4 screws on the back, you have to pull hard to unglue the circuits from the top plastic part (where the buttons are). Then you have to unscrew two more very little tiny screws to remove the the circuit board from the bottom. There is the battery, on the board... but the contacts are welded (2-points)! Cheap electronics! They basically won't go!
Now my remote is definitely dead I think.
So to answer i_trax' question: no, you can't change the battery (it's a CR2025 by the way). But not because it's weather sealed (you could replace the seal pretty easily I think), but because it's cheap electronics.
12-17-2012, 11:01 AM   #10
Just a short follow-up on yesterday's post. I bought a replacement battery. Took a flat screwdriver, pushed hard on the weld. Nothing broke
I put the replacement battery in place, closed and screwed the remote back in place. I aimed at my camera and fired... Yay!
Not sure it is waterproof anymore, but basically you can change the battery, although it's a pain in the ass.
I should note my remote stopped working again after the first shot. I think it has something worse than a dead battery
02-15-2013, 03:34 AM   #11
nanhi's Avatar
You can very easily change the "button cell" in the Remote F. Use a JIS or Philips cross head screw driver to remove the little black screws. Pull the plastic shell apart. Push out the old cell from the battery holder on the tiny motherboard, and push a new one in. Close it up.
Chinese ones fro evil Bay cost $ 2 t0 3 and work just as well.
Now I cannot understand how you can get these tiny devices wet? I think the waterproof O-RC1 Remote is just a high priced gimmick.
02-07-2014, 03:03 PM   #12
JayGeePhoto's Avatar
Remote Battery Blues
Half way through the diss-assembly the remote decided to work again. Perhaps the battery was out of place. I would however like to know there's new fresh (relatively) battery in there.
The way you can tell if in fact a remote control is working even without it's paired device is to press the button and aim it at your video or live view camera - the digital sensor can see the infra and near infrared - you will see it flashing! In so far as getting it wet. It's nice to have devices that you don't have to worry about when you are outdoors. I love to set up my WG3 with a little grip-pod to take group photos even when it's raining. Doesn't everything get wet sooner or later in India anyway?
02-07-2014, 09:01 PM   #13
JJC remote works well and is very cheap. Easy to replace slide out battery compartment too.
02-07-2014, 10:41 PM   #14
JJC Card Style Compact IR Remote for Pentax / Samsung Cameras (E7) #00075771
Is this the one? I see it advertised for $5.99. I suppose that it can be made waterproof by placing it in a ziplock bag.
02-08-2014, 05:47 AM   #15
nanhi's Avatar
For the cost of a replacement battery, I bought a UNIVERSAL REMOTE for a paltry $ 2.99 with FREE shipping from an eBay Seller called "buyhere99" -
see attachment. Works great with my K-5 and K-20D. Worked well with my nieces Nikon 5200 too. More grippable than the Pentax Remote.
I have seen this model plastered all over eBay and Amazon com for almost the same price.
The battery tray slides out at the press of a button and you can put in a new battery when the old one dies (estimated life of 3-years). Again batteries are very expensive in the US (one-fourth the price here in Bangalore), so why buy a battery when you can buy the Remote for the same price or even cheaper.
I just do not know how these Chinese manufactures ships it thru USPS - yes with USPS / CHINA POST dual labels - for a paltry $ 2.99???
I have used USPS and I can tell you it would cost twice more than the $ 2.99 for shipping alone in the US.
Regards.
camera, control, mirrorless, pentax, pentax q, pentax q10, pentax q7, proof, q10, q7, water
PENTAX Waterproof Remote Control O-RC1 vs. Remote Control F jpzk Pentax Camera and Field Accessories 8 12-02-2013 08:11 AM
Opening an O-RC1 remote? rlw1138 Pentax Camera and Field Accessories 4 12-16-2012 06:52 AM
water proof. rlatjsrud Troubleshooting and Beginner Help 28 07-25-2012 09:23 AM
Remote O-RC1 schneider Pentax Camera and Field Accessories 10 11-24-2011 12:23 PM
For Sale - Sold: Pentax K-5 Body LNIB w/ O-RC1 WR remote and 2nd battery wintercount Sold Items 2 10-12-2011 05:09 AM
All times are GMT -7. The time now is 01:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
