05-05-2012, 07:25 AM   #1
How to get back to default settings?
I have problems going through the whole manual on my computer because I'm using the speech recognition software on my computer. Not using my arms much due to tendinosis. However, I bought this camera during winter and was going to start using it this spring. I think I may have screwed up some settings. Is there any easy way to get back to default setting?
I don't know what have happened, but every time I take a picture, it takes for ever for the camera to process. Is that normal, or have I screwed up some setting?
I have to say I am a bit disappointed about this camera. It is a bit too complicated for me and I wish I had an ordinary user handbook. I will have to print out the PDF file. I used to have an SLR non-digital, but this is more complicated. :-)
Askeladden
05-05-2012, 08:22 AM   #2
I'm sorry about the formatting in my post. It happens because I'm dictating with the speech recognition software called Dragon naturally speaking.
However, I found out why the processing took so long time. I had changed the setting to something called "HDR capture". I'm not sure what the difference is. But the processing went faster without.
I do have some problems when taking the picture. Because it takes time to focusing, I am not able to shoot the picture as fast as I want. It's probably something I'm doing wrong. LOL
05-05-2012, 09:04 AM   #3
i_trax's Avatar
Hi, the Q is my favourite camera,there must be a reset sequence in the menu to fix your problem, will go and look at my Q.
I took well over 3000 pictures recently with it, absolutely no problems, and I highly enjoyed it.
Yes , it is , in the MENU ,on the eight page, right on the top there is a reset option ( returns to default settings) , just select yes option ( my firmware is 1.01).
05-05-2012, 11:21 AM   #4
Thank you so much! I found it.
That sounds promising! About your experience and mean.
bit, camera, computer, default, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Default Settings? matsui255 Troubleshooting and Beginner Help 5 06-18-2010 01:27 PM
Pentax K-7 Default Settings consiglieri Pentax DSLR Discussion 8 01-03-2010 11:24 PM
10D Default or custom settings? beaumont Pentax DSLR Discussion 7 08-28-2008 06:45 AM
What do you use for default settings? ccallana Pentax DSLR Discussion 6 07-19-2008 02:22 AM
K100D default settings CRMassart Pentax DSLR Discussion 6 11-14-2007 06:34 PM
All times are GMT -7. The time now is 01:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
