Hi everyone,
I just got a Helios Multifinder MKII and was originally planning to use it on my EP1 with my 17mm since I already have an EVF for the EP3. For those who don't know the Multifinder has brightlines for 35mm, 85mm, and 135mm but none for the standard 50mm but I thought what the heck and tried it out with the Q.
Either by human error or because of the location of the hotshoe on the Q I found that the 35mm lines matched up almost exactly with the 01 Lens. I tried it by taking a few pictures and almost each one had almost identical framing between the 35mm lines and the 01 Lens. The difference was so minuscule that I think I will use it more on the Q with 01 than on the EP1 with the 17mm.
Does anyone know why or how the multifinder is matching so well with the 01 lens?
Thanks!
