09-10-2012, 12:50 PM   #1
crewl1's Avatar
Pentax Q-K adapter vs ebay
I have a Q on it's way to me and was wondering if I should go with the Jinfinance ebay adapter to use with my K lenses, or wait for the Pentax one to be available/announced.
What is the advantage of the Pentax version with shutter built in?
09-10-2012, 02:09 PM   #2
Excellent question. I bought a used Q kit including a no-name K to Q adaptor and I too look at the $290 brand and wonder what in the world can make it ten times the cost? The cheap one has aperture adjustment, lens release tab and no electrical contacts....just like all of them. I have seen a few with baffles inside that claim to reduce stray light from hitting the sensor.
Seems reasonable to start with a cheap version to confirm you want to use one at all. But I will be following this thread hoping someone with knowledge of both the $29 and $290 versions can educate us.
09-10-2012, 03:08 PM   #3
wanderography's Avatar
I would wait, what if they announce that it has a built in shutter with electrical contacts that allow it to have shake reduction with adapted DA and FA lenses... never know and you only gotta wait a few days to find out...
09-10-2012, 03:10 PM   #4
JinDesu's Avatar
Does the ebay adapters allow aperture control? If not - the advantage of the Pentax one also includes the ability to use with DA lenses.
09-10-2012, 03:11 PM   #5
wizofoz's Avatar
QuoteOriginally posted by bmonki Quote
I'm in the same position of wondering what do do, and have decided to wait and see what comes up in the next week or so.
09-10-2012, 03:18 PM   #6
QuoteOriginally posted by JinDesu Quote
Ya, some have aperture control on them. I would honestly wait, the official one looks really nice and as compact as it can get for a k-mount adapter. And I think it's already official that it has a built in shutter, the other bits about SR is just "I hope" comment...
09-10-2012, 03:30 PM   #7
If I had DadiPentak's money I would just buy them all and toss the ones I dont like.
09-10-2012, 05:28 PM - 1 Like   #8
The Pentax branded adapter has an integral leaf shutter. The advantage should be that when used with flash, we should get 1/250 sync with external flash and 1/1000 sync with the pop up flash. This might not seem important until you try to take some macros oudoors with an external flash. You'll find that with the adapters with no shutter, your sync speed is 1/13, and there is no way to allow the flash to be the sole or main source of light. I already have an RJ adapter, and will be getting a Pentax OEM as soon as they become available. It's not a matter of being rich or just wanting to spend money. If you don't plan to shoot macros with flash, and only want to get the tele advantage, then any of the adapters with aperture control will do fine, and you can save your money.
Scott
09-10-2012, 05:54 PM   #9
Pentax UK has announced adapter!
Photoblogdotcom has a press release from Pentax UK announcing the adapter( hope this is legit). It does have a 5 bladed shutter built in, and with a firmware update will allow us to input the focal length for image stabilization. HALLELUJAH! They also talk about the advantages of this adapter. Strange that the tripod adapter is an option. Can't wait to order mine. Hope it is less money than the camera.
The Q is alive and very well!
thank you Ricoh/Pentax.
barondla - so happy.
09-10-2012, 06:13 PM   #10
Agree with snostorm and have another advantage to add. The shutter will eliminate the "rolling shutter" effect that happens, with rapid movement, on both stills and videos. Press release pic doesn't show lens mount and doesn't mention if there are electrical contacts. My guess is the Q mount will have contacts to work the shutter and the Pentax K side won't.
Can't wait to get mine. Now, if they will make an adapter to connect their red dot scope to the hotshoe- tightly, they will have a killer package. They should offer it all together with the DA*300. Birders would buy it.
Q on the move!
thanks
barondla
09-11-2012, 03:40 AM   #11
Yep, the adapter looks more real now. Though availability is just mentioned as 2012 without detail, contrary to other products that have more specific dates.
Quoting "JohnCPentax" from his Q&A session on DPR:
If I understand they system correctly, this information is automatically communicated (since all Q lenses would have this information). We haven't tried it with non-"modern" lenses, but the camera likely defaults to a preset focal length.
If you read what he writes it's not sure there will be a firmware upgrade since it would seem the focal length would be communicated automatically. How that could be done is a mystery since the pictures don't show contacts at the side of the K-mount. The only alternative is manual input thanks to a firmware upgrade indeed...
He does mention not having tried it with older lenses, implying that he did try it with modern lenses. So at least it's a real product or a working prototype, not just an empty show case model anymore...
I'll probably be ordering, most likely with the tripod mount (hopefully they won't charge too much for that?). It might turn out to be an expensive few months, esp since I might upgrade to the K-5IIs (undecided until real life results) and I am most certain to get the Samyang 24 T/S.
Wim
09-11-2012, 06:58 AM   #12
crewl1's Avatar
Based on Snostorm's explanation of the requirement for a shutter relative to flash, for my intended use (tele/non-flash) I went ahead and ordered the $29 Fotodiox aperture+tripod mount adapter.
If there turns out to be a reason the Pentax adapter is desirable I will consider it, but by the time it becomes available I would hope to have taken many shots with the cheap adapter and my current lenses.
I also don't see any contacts on the lens side in the pictures of the Pentax adapter so it doesn't seem that it will have any type of communication with the lenses.
If they enable SR for adapted lenses via firmware I hope that function is made available for the Q and not just the Q10.
09-11-2012, 07:04 AM   #13
I'll tell you why you want the Pentax adapter instead of the other versions:
the built in leaf shutter allows taking pictures without any rolling shutter effect (which is a problem with the Q).
Additionally you should be able to get flash sync speed of up to the shutter speed (1/1000s), if the firmware allows it.
09-11-2012, 07:33 AM   #14
crewl1's Avatar
QuoteOriginally posted by LamyTax Quote
When does this problem occur? Is it evident in static, tripod mounted shooting or only when trying to shoot handheld with an adapted lens?
09-11-2012, 07:41 AM   #15
froeschle's Avatar
Pentax Adapter Q for K-mount Lenses B&H Photo Video
Price: $249.00
adapter, camera, ebay, mirrorless, pentax, pentax q, pentax q10, pentax q7, q10, q7
For Sale - Sold: Pentax Mount Adapter K (M42 adapter) séamuis Sold Items 2 07-12-2012 05:50 AM
Pentax D-BG4 + SMC-F AF Adapter 1-7x on AU eBay i_trax Pentax Price Watch 1 06-30-2012 05:45 AM
RJ adapter and coming Pentax adapter? pinholecam Pentax Q 11 02-17-2012 02:02 PM
T2 to Q adapter now on eBay rawr Pentax Q 1 10-19-2011 08:57 AM
Adapter Nikkor AI to Pentax K at eBay (good or bad?) Illuwatar Pentax SLR Lens Discussion 6 03-30-2009 01:18 PM
All times are GMT -7. The time now is 03:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
