Hi enoeske,
There's also the Rayqual, but it's not easily available (need to order through a Japanese distributor), and
very pricey (can't recall but over $300 USD shipped seems to ring a bell -- I inquired when they were first announced and posted it here somewhere. . .). It does have an aperture control ring, and was possibly the first available from anyone.
mount adapter
Personally, I have two. I initially bought a Bower K to C and used it with a Kipon C to Q. This combination worked with many lenses, but would not focus past about 15' with at least one. I inquired early at Fotodiox (actually went to their offices in Waukegan) and they were only in the "looking into it" stage at the time, so I bought the RJ adapter when it was released, and have been using it since with good results.
Edit: crew1 posted while I was typing this, and I'll add that with the RJ adapter that I have, mounting K lenses is very smooth -- and might even seem loose. Mine is a very early one, so I don't know if that might make any difference. . .
The Fotodiox with aperture control visually looks a lot like the RJ, Don't know if it's a knock off or made by the same mfg and rebadged -- haven't seen one close up so can't say. . .
The Novoflex obviously, from the photo certainly has build quality going for it, but I don't know how much of this can be justified in the price differential with the inexpensive Chinese adapters that do work fine.
The Pentax OEM has the shutter, and this will differentiate it from the rest. The assumption is that the coming firmware update will allow SR FL input with it, and it will allow mechanical shutter speeds up to 1/1000 (and assume that faster shutter speeds can be accessed with the electronic shutter when the adapter is mounted, as is the case with the Q Quality line lenses). There has been no information that I can find about flash sync, so that's still a question, but I hope that external flash compatibility with adapters will also be addressed in the firmware. We'll just have to wait and see what happens. Regardless, I've been told by my dealer that they will be ordering at least one when they become available, along with the new 06 tele zoom, and I'll be notified when there's any news.
Scott
