09-30-2012, 06:42 AM   #1
Wide angle C mount lenses?
Has anyone tried any of the really wide angle C mount lenses?
For example:
CCTV LENS - 2.5MM Wide-Angle Lens C-Lens - Spysonic
Also, has anyone ever seen any adapters for M12 board mount lenses to Pentax Q mount? I believe this lens is a board mount but it would be fun to try on the Q.
COP L017S Mini Lens 1-7mm Ultra Wide Angle Lens Fish Eye View | COP
Thanks,
Shawn
09-30-2012, 07:35 AM   #2
panoguy's Avatar
Be careful with that first one - "CS-mount" has a different (smaller) flange focal distance than C-mount (12.5mm vs. 17.5mm), so the C-mount adapter shown probably has additional glass in it to compensate, further degrading whatever image quality the original lens had. You'd be better off finding (?) a CS-Q mount adapter and using it that way, since the Q has a flange distance of 9.2mm. However, I've never seen a CS to Q adapter but here is an option...
The rule of thumb is that you can adapt a lens with a larger flange focal distance with a simple extension and almost no degradation, but lenses with a smaller native flange distance are next to impossible. Hence the reason you don't see many rangefinder lenses on DSLRs! Going from CS-mount to C-mount to Q would be kinda backwards...
Also, caveat emptor, as this fleabay listing for something quite similar (sold as "C-mount") looks to be CS with the adapter already screwed on... and more than double the price of your original link! A good question for that seller would be "Can this lens be used on a CS-mount camera?" If the answer is "yes, remove the back" then you know you're already looking at a degraded optic.
EDIT: here is a wide-angle option that is very high quality (Computar), if you can find a CS-mount to Q-mount adapter (or make one).
09-30-2012, 08:14 AM   #3
"Be careful with that first one - "CS-mount" has a different (smaller) flange focal distance than C-mount (12.5mm vs. 17.5mm), so the C-mount adapter shown probably has additional glass in it to compensate"
I don't think that is the case. If you look at that page the C mount version of that lens is a different lens entirely, it looks as if it is fixed focus.
I have not seen an adapter to go from CS lenses to C cameras. All the adapters I have seen are for C lenses on CS cameras, in that case the adapter is just a 5mm extension ring. Those are also sold as macro rings for C mount lenses.
Shawn
09-30-2012, 09:10 AM   #4
panoguy's Avatar
QuoteOriginally posted by Shawn67 Quote
Ah, looks like you're right. That's a really confusing catalog listing!
In any case, if you want decent image quality, I'd suggest looking at modern (which these days means CS-mount and/or "megapixel" labeled) Computar, Jenoptik, or Pentax lenses. If you just want an adaptable wide angle, these no-name brands might produce a good image, but more than likely not. I've used older C-mount and Bolex lenses on a 1.2MP video system, and they were outresolved by that sensor (ie: blurry crap)!
10-06-2012, 06:38 PM   #5
My C mount to Pentax Q adapter arrived today. I didn't end up getting it till late at night. I can confirm that the 2.5mm lens linked to above is a C mount and works on the Q. It should work out to be about a 14mm FF FOV. I think the Pentax Fisheye is about 18mm.
The lens is not fixed focus (the front thin element moves) but it is fixed aperture. It does not cover the entire sensor, you get the traditional fisheye circular view. I think it is considerably faster than the Pentax Fisheye. I took a shot of my floor with the 01 Prime wide open at ISO 125 and it center weighted metered to 1/30 of a second. With the 2.5mm lens it metered to 1/13th of a second. In theory it is around f2.8ish.
Should be fun to play around with this lens more, esp. for $23.
BTW, I would not try this lens on other cameras. It projects fairly deeply into the camera and I would be very worried about it interfering with a mechanical shutter... since the Q doesn't have one....
Shawn
PENTAX Q  Photo
PENTAX Q  Photo
10-06-2012, 07:26 PM   #6
Guakala's Avatar
Wow that looks great for $23! Can't wait to get a Q.
10-07-2012, 09:42 AM   #7
Shawn67 this looks like an interesting circular fisheye for the Q. Could you post a full size pic or two so we could judge the IQ ?
Also a lil bit of research yielded this lens for $16 at L025F - Fixed Iris Lens C/CS Mount 2.5mm F:1.6 1/3" | COP, USA, Video Surveillance, CCTV Equipment, Camera, Security Products, Surveillance Equipment, Security Camera, Surveillance Camera
Thanks!
10-07-2012, 05:59 PM   #8
Sure, IQ is interesting on the lens. It seems to do better closer up. It will focus in very tight. On the flowers I was an inch or less away from them and I think it could still focus even closer. As you can see in some of these it does have some CA. I did not try correcting this in LR4 to give a better representation of what the lens is doing itself. I think most of the CA could be removed in LR4. For the same reason these have minimal PP to them.
To focus on these I was using a loupe on the LCD with magnification on the LCD.
If you right click on any of the pictures and view this picture you will see a larger version of the picture that you can zoom in more.
Shawn
10-08-2012, 08:51 AM   #9
wow thanks Shawn! looks like it gives about the same IQ like those add-on fisheye adapters .. ok in the center, pretty bad along the edges.
i do like your closeup shots!! that's it's best application.
10-12-2012, 04:59 PM   #10
Here is another C mount wide angle option for the Q. These are from a Pentax/Cosmicar 4.8mm f1.8 C mount lens. This is fixed focus lens that is equivalent to about 27mm. Just a couple of test shots at f1.8, 2.8,4 and 5.6 before I lost the light. For street shooters this may be a nice lens. With the adapter the lens is a little longer than the 01 prime but still looks fine on the camera, no worries about focus and the electronic shutter is silent.
Some completely boring shots at different apertures to see how the lens does....
f1.8
f2.8
f4
f5.6
Will try this lens out more this weekend
10-13-2012, 08:16 PM   #11
Posted a number of shots from the 4.8mm C mount lens at:
https://www.pentaxforums.com/forums/pentax-q/172196-lets-share-shots-q-30.html#post2134234
Shawn
10-20-2012, 09:58 AM   #12
I ended up picking up a few more C to Q mount adapters.
The adapters are nice as they are two part to allow you to rotate the lens so that the aperture scale is upright. This also allows you to shim a lens if needed. From my testing the Pentax 4.6mm fixed focus lens needs a little shimming on the Q. I ended up taking apart the adapter (3 allen screws) and added 3 small squares of paper from a sticky note between the two pieces of the adapter and reassembled it.
This is a 1:1 comparison (from the center of the lens) in LR4 between the adapter with no shims vs. the adapter shimmed with the paper.
Getting the lens shimmed improved focus all over the lens, objects close up are sharper now too. BTW, the comparison function in the Qs playback menu was really nice is helping me to see the need for the shims in the first place.
Shawn
04-30-2017, 03:41 AM   #13
Wide lens
Hi everybody,
please could you recommend me any sharp C or D wide lens (wider than 5mm), that is useful for architectural photo? 08 is very expensive for me.
Another question - what do you think about using 0,45x convertor with 01 lens? Is it useful?
Please share your photos, shoots from the past disappeared here..
Thanks,
P.
04-30-2017, 08:49 AM - 1 Like   #14
Cipher's Avatar
Architectural photography usually requires edge to edge sharpness. Wide angle D mount lenses won't cover the Q sensor without a serious drop off in quality and/or vignetting at the edges. A quality wide angle C mount lens will be much more expensive than the 08 and not nearly as wide. There are CCTV lenses that are wide, but they are designed for smaller sensors and will not cover either Q sensor size. The 08 is by far the best candidate for the Q system, there is one for sale on the forum marketplace for $310 USD right now. I got mine used for $210 USD, so they can be had for less than the $350-500 that they usually cost.
05-04-2017, 12:31 PM - 1 Like   #15
Thanks for your reply. So it sounds that 08 will be nice choice in the future.. I am from Europe, so marketplace isn't very advantageous in terms of price and delivery.
And what do you think about 01 + 0,45x wide angle convertor? I am very curious about barell distortion a loss of sharpness, loss of light..
angle, board, camera, cop, lens, lenses, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
wide angle lenses laura89 Pentax SLR Lens Discussion 15 04-24-2011 05:42 AM
k-mount MF wide-angle shift lenses asaru Pentax SLR Lens Discussion 5 02-20-2011 10:18 AM
All times are GMT -7. The time now is 12:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
