Originally posted by hiwaystar When you are using a MF Pentax K zoom lens with a 3rd party adapter and the 1.1 update, what should be put in the FL measurement, the short or long FL of the lens?
And what should the aperture of the MF lens be set at?
Thanks for any input on this.
In practice, it is easier to use a fixed focal length "prime" lens.
When using a MF Pentax K zoom, you should either:
1) Turn Shake Reduction off (or)
2) Input the focal length the zoom is set to. You should be able to read this off the lens barrel. You would then enter the set focal length in Menu 3, "Input Focal Length".
As for the aperture, it is any setting you choose. Wide open will allow a faster shutter speed, but will probably be softer. Closed down, the depth of field will be greater.
Make sure you set the Q to AV (aperture priority mode) so the camera will meter and set the "correct" shutter speed for you.
