10-24-2012, 06:41 PM   #1
Checking sharpness on rear LCD question
This might be one of them dumb questions, but it's not the first (nor last) I've asked.
On my K7/5 I'd jump to 11X mag on the rear lcd to get to 100% view(1:1) for checking post capture focus/sharpness of the image. I read somewhere that was what to use. Looking for the answer for the Q, I read it 8X seems more correct for the K7/5, but I never found an answer (or even talked about) for the Q.
Does anyone know what ?X to get a 100% view on the Q's LCD? What do you use?
Is it as simple as (12.4m/450k)/3=9.1, closest on Q would be 9.5X
Thanks
10-24-2012, 07:23 PM   #2
No idea what to use for 100% on the Q. I usually review at 4X or the next step. The review jpeg is probably smaller than on the K cams to allow faster lcd viewing. Q has much less buffer memory/processing power.
thanks
barondla
Also remember the Q lcd screen has less rez that K cam.
10-25-2012, 01:14 PM   #3
Riv
Interesting, so we don't the size of the file, nor how it's being processed from raw to jpg for review. I never really considered that we weren't seeing the actual image as it was captured.
10-25-2012, 07:28 PM   #4
All digital cameras show a small jpeg thumbnail on the lcd. There is no point in using a 12mp file on a 3" lcd. The only time this is a disadvantage is when magnifying the pic on the lcd. Mag too much and the small file will look soft. The full size size file can look sharp on a computer monitor or when printed( as long as the shot actually is sharp and in focus).
If you shoot Raw the lcd still shows a small jpeg. The histogram also shows jpeg info. Raw shots can be pushed harder to the left of the histogram.
thanks
barondla
answer, camera, k7/5, lcd, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
How do i turn off the rear LCD panel derek45 Pentax K-r 20 04-06-2012 12:46 PM
Checking Focus on Rear LCD arnie0674 Pentax DSLR Discussion 9 01-29-2012 10:47 PM
K100D Super Rear LCD Issue malfunction54 Pentax DSLR Discussion 3 07-20-2011 08:22 AM
K10D Rear LCD Problem cajun0518 Troubleshooting and Beginner Help 6 07-08-2011 09:57 AM
Rear LCD Problem slpslee Pentax K-r 7 11-19-2010 03:19 PM
All times are GMT -7. The time now is 08:14 PM. | See also: NikonForums.com, part of our network of photo forums!
