Originally posted by crewl1 Going by the samples that are already in the list I would enter lens focal length. They show 15, 21, 77 etc.
Let us know how that works! The admittedly pre-production Q10 with the SR for adapted lenses that I tried out worked much better with the "multiplied" focal length, at least for the DA*300/4 I tried handheld (which meant 1650mm was entered). When I used the actual focal length of 300mm, which makes much more sense BTW, the results were blurry as if SR wasn't on at all, but 1650mm gave sharp results. Might've been the firmware... hence the request for tests!
