Originally posted by jpzk Questions: 1. Shooting JPEG first, to get used to the Q ? 2. Any sense in installing the software (CD) that came with it ? I have CS5 and Faststone Image Viewer already on my computer. 3. What would be the optimal SD card to use ? 4. Any specific settings which would render the learning phase easier ? 5. Any sense in updating the firmware yet ? Seems that the firmware updating is not done the same way as I usually do with my K7, K5 ... frankly, I haven't had the time to check that yet. Cheers! JP
1. Your call, it lets you try the image filters which are fun.
2. I did not, I use LR4 and it fits right into the flow that I use for the K-5
3. See
https://www.pentaxforums.com/forums/pentax-q/204434-sd-card-type-best-used-q.html
4. None that I can think of learning, there are some settings recommended in the thread 'Share your shots with the Q' for tuning the sharpness, etc.
5. It can wait, till you want to use adapted lenses, but the Peaking is nice if you want that.
Originally posted by LaurenOE Add another question - Where is the lens hood for the standard zoom?
You will have tobuy one, not sure if it comes with the lens when by itself. I got this one
Professional Replacement Lens Hood MH RA40 5 for Pentax Q 8 5mm Lens Silver | eBay
