11-09-2012, 01:50 PM   #16
drougge's Avatar
QuoteOriginally posted by wombat2go Quote
If I were doing an adaptor I would first make a diagram like the one I did with assistance from MysteryOnion for adapting Pentax 110 to M43:
https://www.box.com/s/b9319930073aad14e911
It would be necessary to check that the CS register of 12.526 mm can be met with sufficient annular metal in the adaptor.
I see that the CS thread is 1 inch by 32 tpi so it would need to be cut on a USA or old British lathe, or a Metric lathe that has leadscrew gears that can do a pitch of 1/32 inch which is 0.7937 mm. If the CS mount was invented in USA it will have thread angle of 60 degree, if British, probably 55 degree.
The way I do the bayonet mounts is to take a body cap into my (dirty) workshop and measure it as accurately as possible and replicate on the lathe,
leaving enough metal to finely adjust by trial fitting the new adaptor into the camera body.
I think a very high accuracy ( maybe 0.02 mm ) on the register will be needed, especially if a variable focal length (zoom) lens is used.
I feel a bout of lazyness coming on just reading about it. Maybe the Chinese will start making adapters soon. (I expect I will at least take the problem (and this information) to some hackerspace and see if someone feels like helping with it. Once my adapters arrive that is.)
QuoteOriginally posted by Erich_H Quote
You can do that with a big lens like that. All (4-5) CS-lenses I've seen live has been really small and cheaply built as opposed to your lens. Did you buy your lenses in Sweden?
I would probably try to prop the lens up. The Chinese lens is from ebay, the zoom I bought locally.
11-10-2012, 08:57 AM   #17
panoguy's Avatar
QuoteOriginally posted by drougge Quote
I just ordered a cheap CS lens (6-60mm f/1.4-1.6... how's that for variable aperture!?) and a one-piece D-mount adapter to hack up. A friend has a metal shop, so I'll give "adapting the adapter" a go... of course, I'm still waiting for my Q-mount camera to arrive!!
adapter, camera, crappy, f/1.0, lens, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
So I finally bought a k-5.... zosxavius Pentax K-5 16 09-23-2012 06:35 AM
Okay ... so I bought the K-01 Christine Tham Pentax K-01 45 06-16-2012 11:20 PM
So I bought the K7...thought at first it was great, then I used it in the field... crossover37 Pentax DSLR Discussion 263 05-20-2011 12:39 PM
Finally Bought Some Decent Lenses! Colorado CJ Pentax SLR Lens Discussion 13 12-05-2010 12:11 PM
I just bought a used K10d so here's some photos from today pasipasi Post Your Photos! 5 09-17-2008 07:32 AM
All times are GMT -7. The time now is 09:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
