11-11-2012, 02:17 PM   #1
hnikesch's Avatar
Lessons learned
I tried my luck to today with K mount lenses and it was not good. I couldn't see the LCD out in the sun, partly because I hadn't set it to it's brightest, and I use photo-gray glasses and they were dark, also I left my LCD hood loop home. All my fault, LCD is now set. I started with my Super Tak 200 and that is tough to hand hold. I think I will get used to things with my 135 (EFL 750) first then move up. Bracing the hood to my face also helps steady things and it's easier to follow subjects. I also found that if I leave SR running it is easier to hold on to a subject. So far no keepers.
Hans
11-11-2012, 03:40 PM   #2
It does take practice to get results from the Q with long lenses. The SR helps a lot. Before SR, I could get a decent percentage of keepers at 135mm or less. 200 was almost impossible, unless in bright sun. With SR I got some keepers using the 55-300 zoom at 300 ( thanks for the push snostorm) the first time out.
thanks
barondla
11-12-2012, 10:37 AM   #3
crewl1's Avatar
Longest I've attempted hand held is the 100mm macro but that was pre firmware 1.10.
Bright sunny day and fast shutter speed helped.
camera, hood, lcd, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Streets 1st time in 35 years / Real or Fake HDR / Lessons Learned slackercruster Photographic Technique 3 07-30-2012 06:12 AM
Had a big oops, near misses and lessons learned. PPPPPP42 Pentax DSLR Discussion 4 03-03-2012 12:34 AM
Vacation - Lessons Learned cali92rs Pentax DSLR Discussion 10 09-12-2011 07:35 PM
Lessons Learned at a train garden... SlickYamaha Photographic Technique 5 01-01-2011 04:29 AM
Credit Cards and Lessons Learned Ed in GA General Talk 5 04-24-2007 08:52 AM
All times are GMT -7. The time now is 06:04 PM. | See also: NikonForums.com, part of our network of photo forums!
