11-20-2012, 01:52 PM   #1
My Q and A (Adapters)
Ok so in the mail today I found a seaweed green packet and as I picked it up a curl appeared at the corners of my mouth much like when the grinch had his life changing epiphany. It had to be my K and my C adapters. I opened the package and pulled out the two boxes and yes my life was changed. The first thing I did was put the 40mm pentax-m pancake on to see if it fit in my retro PU leather case and yes very snuggly it fit I shot some samples and then all of a sudden my room was a shambles of M,K and M42 lenses strewn about. I figured I would start a new thread as I have LBA big time and why ...Because the old lenses are what I call "Character Lenses" and the Q is like that perfect talk show host that brings out The true personality of each lens...so begins the chronicles of Q&A.
Pics to follow
11-20-2012, 01:58 PM   #2
crewl1's Avatar
Heh heh - you are in for some fun. At some point someone should start a list of what lenses cooperate well with the Q and adapters.
11-20-2012, 02:11 PM   #3
First off I am going to give my impression of the most conveinient way to use the K adapter Handheld with manual lenses.
1. Use M mode
2. set the camera to auto ISO
3.Use focus peaking don't use focus multiplier if you dont have to.
4. Use dial to set shutter speed to about 1.5X the actual focal length of the lens you are using so 100mm=1/150
5. Cradle the lens in your Left hand taking the weight off the body and adding stability.
6. Use your right hand for camera control
7. antishake on
I think this is a great way of assuring you avoid camera shake as no photo editing software can fix camera shake. It also allows you the freedome of adjusting your aperture without worrying about shutter speed diving to unmanageable depths. Lastly the Q to me has very esthetic noise and even if you get noise it's charming
11-27-2012, 06:00 PM - 1 Like   #4
Ok here is drastic photo comparison the moon was very small but clear first shot with 01 prime(47mm equivalent) second withPentax-K 400mm at ~f8(2240mm equivalent) on my k>q adapter Neither photo is cropped
11-27-2012, 06:16 PM   #5
Ok this lens like many of the old lenses has a problem with purple fringing when bright background is present. In this shot there was very slight blue green fringing in a very small range so it was very easy to remove using Pixelmator hue tool. I plan on taking it out on the next sunny day I get I will likely do some photos from a highpoint to prevent fringing.
11-27-2012, 06:51 PM   #6
baro-nite's Avatar
In my brief experiments with moon shots, I discovered that longitudinal CA is actually helpful for focusing on a high-contrast edge -- zoom in and watch the edge go from green to magenta; pick the spot in the middle. Well done on the shot with the 400, that is huge magnification!
11-27-2012, 08:10 PM   #7
Here is a really noisy example because of poor lighting. 50mm(70mm equivalent) on KX vs 400mm on Q(2240mm eq) Again no cropping
11-29-2012, 07:20 AM - 1 Like   #8
Heres what it looks like mounted on the pentax-k 400mm 5.6 lens didn't use the vivitar macro teleconverter yet.
11-29-2012, 07:54 AM   #9
LeRolls's Avatar
BEAST! Love the flexibility of the Q!
11-29-2012, 03:06 PM   #10
Docrwm's Avatar
QuoteOriginally posted by Sliver-Surfer Quote
That reminds me that I have yet to use my Q with my K300
11-29-2012, 03:32 PM   #11
baro-nite's Avatar
What I want to see is a Q slapped on the back of an FA 600/4. I'm only half joking ...
11-29-2012, 04:59 PM   #12
Docrwm's Avatar
QuoteOriginally posted by baro-nite Quote
We saw pictures and read reports of it on the new 560 at Photokina Seemed to work rather well from the reports.
11-29-2012, 05:42 PM   #13
baro-nite's Avatar
Saw that, but at f/5.6 the Q won't get the best out of that lens. Hence my wish to see some samples from the 600/4. I cannot imagine ever buying one, so it's more theoretical than practical for me. Also, it would be very funny.
12-04-2012, 09:06 PM   #14
Here is a combo I Just like alot cuz of the cool factor and they seem almost made for each other
Yes it does fit in the case
taken with Q
12-15-2012, 10:31 AM   #15
volosong's Avatar
Sliver-Surfer, how do you like your case? Do you find the PU leather holding up well?
camera, lenses, life, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
thoughts on Novoflex Pentax Q adapters? claud9999 Pentax Q 7 08-12-2012 10:25 AM
Leica M and Nikon G adapters announced for Pentax Q Urkeldaedalus Pentax Q 4 02-25-2012 10:39 AM
Various adapters for Pentax Q ogl Pentax Q 19 09-23-2011 01:15 AM
All times are GMT -7. The time now is 11:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
