edit: Red Text are 24Nov updates
Results from some testing today.
Parameters, Camera was setup in AV mode, SR Off, Power Save off, Shut Down Off, AWB, Natural Custom image, No SD card, everything else was off or at the minimum allowed setting. Room temp 67.7d(f). Camera was configured this way because I was testing the batteries, not the camera. Except the SD card, forgot to bring one but it wasn't needed anyway.
Charge Time test, battery was depleted in camera and then placed right on charger with no recovery time allowed.
Aftermarket 1- 38m 42s (charge #2 38m 12s), Voltage after charge 4.12vdc, stabilized at 4.06vdc
Aftermarket 2- 1h 19m 10s (charge #2 1h 16m 54s), Voltage after charge 4.15vdc, stabilized at 4.09vdc
Pentax OEM- 1h 41m 46s (
charge #2 1h 42m 24s), Voltage after charge 4.17vdc, stabilized at 4.15vdc
Things are looking bad already.
Run time test. Camera aimed at the same target in each test and timed start to depleted message.
Aftermarket 1- 18m
Aftermarket 2- 44m
Pentax OEM- 2h 13m (
ran twice to validate the extreme difference, 2nd run was 2h 9m)
I did one more test, same settings except this time with SR on mode 2 (full time). I put a water bottle on the desk, then set 300mm tripod shoe on top of the bottle, and hand held the camera (
imagine an 8in monopod with long glass). An effort to keep SR actively working. This test included 1 more power on cycle after the first depleted message to insure the battery was dead.
Aftermarket 1- 4m 7s
Aftermarket 2- 28m 29s
Pentax OEM- Based on the aftermarket 2 test I choose not to do this one. I didn't want to work the SR system for what should be over an hour straight.
Clearly Aftermarket 1 is a bad battery. I don't know if Aftermarket 2 is actually bad, or just a flat out lie in labeled rating. I don't have a 2nd OEM battery (yet) to validate the tests for that battery,
but I plan to re-validate the run time test. It scored a lot higher for only 20m longer charge time, ran out of time today.
I think I've shown that camera and the charger are ok. What makes me mad is that I didn't buy $3 aftermarket to avoid all this. These were priced at half the OEM battery, but they appear to be $3 batteries. Needless to say they will be getting a call tomorrow or Monday if closed weekends.
So there you have it, all those hours charging and draining batteries and not a single picture taken
what a waste of a day. But. I got my answer.
Added so you don't have to search all the replies. They were purchased from bestbatt.com @$10 each. I'm sure there are good aftermarket batteries out there. Just be mindful of your source, I thought I was: but wasn't mindful enough it seems. These are nameless batteries imported from China with no manufacture info, pictures of them are a few posts down. But they don't mean much, the labels could change tomorrow. I wouldn't be surprised to learn there are only a couple of companies that make these. Best of them become OEM, next best group becomes Named aftermarket, and all the sub-standard ones go to fleebay and websites like this one. Just like the sub-C racing packs, you had pushed, matched, retail pack and lastly sperate cells that were (20yrs ago) a crap shoot.
