11-30-2012, 01:46 PM   #1
yellowruby's Avatar
DC Coupler for TIme Lapse
I'm doing a time lapse of a cottage being built with my Q. Battery life has been a challenge. I can get slightly over two hours and roughly 250 exposures on a battery running the time lapse at one-minute intervals. I found that the Fujifilm N50 battery (for my X10) is the same as the D-Li68, although the N50 is more widely available and less expensive. Both are 3.6V and 1000mA, and my battery life for time lapse is identical.
Swapping out batteries every two hours has quickly gotten old. I saw that the official Q DC coupler is kind of pricey. Fujifilm makes one for the X10, not quite as expensive, but not exactly cheap. Found this generic DC coupler: AC-5VX AC Power Adapter plus CP-50 Coupler Kit for Select Fujifilm Cameras - BestBatt.com, which arrived today.
It fits into the Q perfectly, although I have to leave the battery compartment door open. Works fine, too. Am looking forward to doing really long time lapse sessions now without the anxiety of battery depletion.
11-30-2012, 05:04 PM   #2
QuoteOriginally posted by yellowruby Quote
Well done! I have the Q and also wanted a DC coupler. I have two Fuji point and shoots that use the NP-50 battery, so I was pleased to find they were the same and that I already had spare batteries. I tried to find the Fuji version of the DC coupler but didn't have your stroke of genius to locate a third party one. Hence I forked out big time for the Pentax brand one...
12-15-2012, 08:03 PM   #3
crewl1's Avatar
Great find yellowruby, mine arrived today.
Since it will be on a tripod for the types of applications I need it for, having the door stay open is no big deal as the Q doesn't complain.
At some point if it bugs me enough I will think about surgery to have the cord come out the other side so it can exit out the port with the door closed.
Its a bargain no Q owner should pass up.
12-15-2012, 09:17 PM   #4
Thank you!
Thanks so much for posting this. I've been desperately wanting the AC adapter for my Q but couldn't justify the cost. I just ordered the Fuji one linked, now i can start planning some good time lapses!
12-16-2012, 01:31 PM   #5
yellowruby's Avatar
Thanks! I've noticed one minor quirk with the Q. If you're doing a really long time lapse, you need to disable "Power Saving" and the "Auto Power Off" options. You'd think that the Q would realize that it ought not turn itself off, but there must be some kind of race condition going on and it gets confused after a couple hours. Its turned off automatically prematurely a few times before I realized that its those power saving/automatic off features.
I don't think the Q "remembers" them, either, so you have to manually set them each time.
I wish there was a way to take an unlimited number of time lapse pictures. The Q is limited to 999 images per time lapse session. At 15-second intervals, that works out to a little more than four hours. I'd rather have the Q keep time lapsing until it runs out of space on the SD card, but I guess I can get by with only four hours.
01-15-2013, 08:04 AM   #6
The generic (Fuji) AC adapter linked above puts out 5 volts / 2 A. The battery is only 3.7 V / 1 A. Have any of you actually connected it and tested with the Q ?
01-15-2013, 08:51 AM   #7
crewl1's Avatar
I've tested it for a short period of time and it worked fine. I believe yellowruby has done long term tests as it was used to capture time lapse shots of a building project with the Q.
01-15-2013, 11:08 AM   #8
yellowruby's Avatar
Correct. I've used my DC coupler for up to eight hour time lapse periods with zero problems. Only quirk, which I mentioned before, is that you need to disable the "Power Saving" and "Auto Power Off" options.
01-15-2013, 04:45 PM   #9
Great! I was concerned about the higher voltage - Thanks for the feedback guyz !!
battery, camera, dc, fujifilm, lapse, life, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, time
Tips for shooting time lapse with K-x + PKTether photoleet Pentax DSLR Discussion 2 04-05-2012 07:06 PM
Suggested Improvements for Time Lapse Sperdynamite Pentax K-5 14 11-09-2011 08:20 AM
Nature Moonrise over DC (Time Lapse) cdurfor Post Your Photos! 3 09-12-2011 06:13 AM
For Sale - Sold: Canon DC Coupler DC-E1 (only the coupler, no power adapter) (CONUS) RayGunn Sold Items 5 12-20-2010 07:04 PM
Video software for time-lapse? shutterdrone General Talk 2 04-04-2008 07:45 AM
All times are GMT -7. The time now is 08:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
