Originally posted by crewl1 In my testing the popup worked perfectly and did not miss a beat.
Just waited for the flash to charge, you can see the little flash arrow turn from red to white when it is ready.
I shot over 20 pics one after the other at 1/1000 and it worked fine.
Perhaps Scott, you weren't waiting for it to be ready?
Hi crewl1,
I waited for the flash charge indicator to turn white. I think that pop up firing reliability with the Pentax adapter and the Q might be production run dependent, which is a bit strange.
I just tried it again, with the same results -- on my older black Q (bought right after introduction) I could not get more than 7 consecutive shots (most of the time 2-5) where the flash fired. I tried both "flash auto" and "flash on" settings in the flash menu. All of these were at 1/1000 -- I'll try other flash menu settings sometime.
Then I switched to my new white Q, and it was better -- avg 7-10 consecutive shots when the flash fired. Again, this is only using flash on and flash auto in the flash menu. This, for me, is not too bad, and I could live with this.
The way I would use the pop up flash for macro would be to fire "digital" optical slaves (optical slaves that can be set to ignore the preflash). My Metz 15 MS1 is a remote wireless TTL flash with my DSLRs, fired with the pop up as the controller, but since the Q can't do wireless remote TTL, the Metz could be set up to fire as a digital slave, and that would be fine with me. I also have two Sunpak PF20 FDs which are tiny manual/auto thyristor flashes that can be used as digital slaves (or, BTW, as probably the most compact hotshoe mounted external flashes around for the Q, but they can't bounce and are manual or auto thyristor only). I also have a very cool Fotopro macro dual arm macro flash bracket (imagine two legs of a gorillapod that can attach to the camera body on one end and have micro ball heads with cold flash shoes on their ends) to mount the Sunpaks on.
I can now fire either of these 100% reliably with either of the small Metz external flashes I have or apparently with 85-90% reliability with the pop up on the white body if I want the whole package to be a bit lighter and smaller. That's good enough for me, but I'm relatively easy to please.
I still want Pentax to give us fully reliable flash protocols for the Q.
Scott
