06-14-2013, 09:18 PM   #16
ScooterMaxi Jim's Avatar
Some folks warn about mounting to a tripod using the Fotodiox shoe, and it is a concern given the two small screws that connect the shoe to the adapter. On the other hand, if you are using relatively small lenses and check the shoe mount every time to make there's zero wobble, you should be OK.
Most of us have found nearly no problems with jello effect up to 85 or 100mm using the generic adapter hand held, some misses up to about 150mm, and a real challenge to hold steady at 200mm and beyond (not to mention the difficulty in finding your subject without a real viewfinder at such high magnification).
The Fotodiox uses a very nice semi-gloss finish that presents an issue with some reflection on the inside of the barrel. I found matte model paint to be particularly easy to apply without concerns about changing the external appearance.
I'm not aware that Fotodiox items - ordered in the U.S. or from HK - take long to be delivered to the U.S. Of course, you never know what can happen at Customs, but such snags seem rare these days.
adapter, camera, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Which to buy, Q or K-01? blackcloudbrew Pentax Mirrorless Cameras 62 03-28-2013 09:10 AM
Original Pentax Q>PK adapter arrives! Mini review. barondla Pentax Q 140 12-20-2012 09:19 PM
Pentax Q / adapter K to Q / DA 35mm f2.4 AL wax Pentax Q 4 11-06-2012 02:55 AM
Which adapter to buy? evalon Pentax SLR Lens Discussion 2 04-27-2012 12:05 PM
K10D owner --> I'm confused, just tell me which lens to buy. Sunnyqueensland Pentax SLR Lens Discussion 21 04-16-2008 03:24 PM
All times are GMT -7. The time now is 02:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
