Originally posted by chriscdg Sunny, thanks for your input. Do you happen to have any photos online that you've taken with that lens?
Hey, I just posted two shots to the "Share your Photos" post. Here's the link:
https://www.pentaxforums.com/forums/pentax-q/172196-lets-share-shots-q-80.html#post2218127
Both are shot at the long end of the zoom (around 250mm equivalent.) Both are wide open (f2.8 on that lens.)
As you probably know, the wide end of this lens is is the long end of the 02 zoom, but you get f2.8 instead of f4.5. However, this is offset a bit by the not-so-close focusing distance (I think around three feet, give or take a bit.) You can still get some out-of-focus backgrounds on the wide end of the 06, but you'll need to be closer to the subject.
Best of luck on finding something that works for you!
