Originally posted by Painter Yes I'm already working on a 35mm f2.8 that should give better results (196mm equivelent) as well as a 5mm 2.8 which will be a 28mm equivelent but that one is proving tough as the registration distance places it inside the Q mount
Wow. You going beyond a pancake with that 5mm lens. Not many lenses the Q can't handle with its ultra short registration distance. Going inside the mount has to be tight as there isn't much room there.
Have to try this later on.
thanks
barondla
