This one is a big surprise. It has some PF on my Kx and K01, so I expected it to be awful on the Q. But... it wasn't that bad. At 28mm it's soft no matter what you do, but at 210mm there's little PF even wide open. It's soft like a purpose-made soft focus lens wide open, with a glow to bright areas and fringing that gets mixed into the glow. One stop down, the glow is reduced and some PF comes through, and two stops down PF is all but gone. At the tele end, this lens performs much better than expected. It's slooooow though. If you want the sharpest photos you're limited to f8 on the aperture dial, which corresponds to approx f11.
28mm f4.2:
28mm f5.6:
28mm f8:
210mm f4.2:
210mm f5.6:
210mm f8:
Charles.
