04-15-2013, 12:10 PM   #466
Day 3 - finally a sunny day to get the "hang of the Q" Takumar F 70-210 at F11.
04-15-2013, 02:06 PM   #467
Otis Memorial Pentaxian
a true hang the q ...very nice!!!!
04-15-2013, 02:17 PM   #468
sigma 500mm view on k5 and q
i think people still stuggle with the drastic distance change with the q and the normal k5...even after using it for awhile i still go wow when i look at the true comparison...i did it on a tripod this time and tried to replicate as much as i could...details on flickr but will try to add here too...low light conditions when i got home...the k5 shots were autofocus and the q manual...iso 125 on q versus 160 on k5...shutter speed the same 1/25...iso f8 on k5 and setting 0.5 on the pk adapter...also took pictures with the iphone to show view..birds on flood wall behind bird bath
iphone
(2)
by pearsaab, on
Flickr
photo (2) | Flickr - Photo Sharing!
cropped iphone
(3)
by pearsaab, on
Flickr
photo (3) | Flickr - Photo Sharing!
k5
IMGA5790
by pearsaab, on Flickr
IMGA5790 | Flickr - Photo Sharing!
IMGA5787
IMGA5787 | Flickr - Photo Sharing!
Q
IMGP1354
IMGP1354 | Flickr - Photo Sharing!
IMGP1350
IMGP1350 | Flickr - Photo Sharing!
IMGP1358
IMGP1358 | Flickr - Photo Sharing!
added the pentax 1.7 adapter so 850mm equivalent
did
additional testing with the q..first 2 had the sigma 500mm plus pentax 1.7
adapter 850mm equiv, last 2 had the 1.7 plus tamron 1.4 1190 equiv..increased
iso to 500 to have enough light
by
pearsaab, on Flickr
did additional testing with the q..first 2 had the sigma 500mm plus pentax 1.7 adapter 850mm equiv, last 2 had the 1.7 plus tamron 1.4 1190 equiv..increased iso to 500 to have enough light | Flickr - Photo Sharing!
did
by
pearsaab, on Flickr
now the tamron 1.4 teleconverter plus the pentax 1.7x adapter plus the sigma 500mm plus the q and qk adapter 1190 equiv
did
by
pearsaab, on Flickr
did
by
pearsaab, on Flickr
04-15-2013, 02:20 PM   #469
hnikesch's Avatar
QuoteOriginally posted by pearsaab Quote
got lucky and found the wood duck this weekend..
Those are great looking duck images Amy, nothing like that around here
QuoteOriginally posted by baro-nite Quote
Pentax Adapter Q. All shots handheld
Nice looking red shouldered hawk good job on the image
QuoteOriginally posted by Guakala Quote
All shots were at 200mm using the Fotodiox adapter
That 55-200 sure did a nice job, sharp images
Hans
04-16-2013, 07:48 AM   #470
Guakala's Avatar
QuoteOriginally posted by M.Zein Quote
Beautiful shots Guakala
Is it possible to change the focal length on the lens without manipulating inputs on the q (or resetting parameters) and still have decent IQ ?
Which inputs are you referring to?
QuoteOriginally posted by hnikesch Quote
Hans
Thanks, I was surprised by how well this lens performed on the Q.
04-16-2013, 08:36 AM   #471
crewl1's Avatar
Whoah 6664 equivalent?! The stacked TC's probably don't give the finest quality out of the camera but a litle PP and you will have a very usable shot. Good experiments!
04-16-2013, 08:37 AM   #472
crewl1's Avatar
QuoteOriginally posted by pickone Quote
Great shot - you may need to start a thread for challenge to find natural Q's in the world
04-16-2013, 11:04 AM   #473
Mamiya-Sekor 135mm/f2.8 M42 Auto
$5 in the local camera store used bins. Original 55mm metal lens hood w/factory UV filter found buried in used lens hoods. Tried 105mm 5.6 yesterday and very soft. 115 today and getting better. Does anyone have a suggestion for tripod support for these older m42 Q combinations? Fotodiox m42 adapter. Another work in progress.
04-16-2013, 03:10 PM   #474
Takumar F70-210 at f8 fotodix adapter
Takumar F70-210 at f8 fotodix adapter -----
04-16-2013, 03:14 PM   #475
Sigma 2.8 MF 50mm macro f8 fotodix adapter
Sigma 2.8 MF 50mm macro f8 fotodix adapter ------
PENTAX Q  Photo
04-16-2013, 03:14 PM   #476
drougge's Avatar
SMC Pentax 645-FA 75mm f/2.8
I posted about this in the MF thread, but it should be here as well.
The SMC Pentax 645-FA 75mm f/2.8 seems sharp enough for the Q. (Of course, it's probably Pentax's sharpest 645 lens (same as the A version), possibly excluding the new made for digital ones, so this is not terribly surprising.)
It's fine at f/4 and f/5.6, acceptable wide open and up to maybe f/11 (where it is naturally softer than wide open). (Quite a bit of PF wide open though.)
These are at 5.6 and 6.7, but not because of any great thought going into those choices. (Full size available on flickr.)
Edit:
And here's one at f/2.8. Not showing the PF, but gives you an idea of sharpness and DOF (at closeish focus).
04-16-2013, 09:36 PM   #477
Sigma 150-500mm HSM OS (Lil' Bigma)
Finally got a couple sunny days and decided to test some lenses on the Q on a local osprey that sits on the top of very tall flood light towers. I was quite surprised with the Sigma 150-500mm @ 500mm, wide open at 6.3. This was 1/400 at ISO 200. Full frame jpeg, SOOC. I forgot that I had it in jpeg mode, so no RAW processed image. I also did some HD video with the same lens, link is below.
Google /Picasa has changed the URL, I guess. I can get the link to appear, but no preview. Anyone know how to insert a Google/Picasa link that will display in the post?
https://plus.google.com/photos/114648824731546075349/albums/5729596022009942...LPZ_Yy_uK3k1QE
Here is the video. The set up was very sensitive to the breeze.
I also tested some older M lenses. I will add results later, but not nearly as acceptable.
04-16-2013, 09:43 PM   #478
crewl1's Avatar
Great video catching the osprey behavior. At 2750mm a sturdy setup is definitely needed as any slight movement is amplified.
04-17-2013, 07:05 AM   #479
Mamiya Sekor 135mm/2.8 above now at 125 reading, handheld some pp iPhoto.
04-17-2013, 08:27 PM   #480
hnikesch's Avatar
The only input that has to be changed if you zoom (change focal length) is the focal length setting for Shake Reduction and you can be off quite a bit on that and still get a good image, If I don't know what focal length I will be using I will set the SR at the mid point of the zoom. I try to be more accurate if possible.
Hans
200mm, 50mm, adapter, auto, camera, f1.8, f2.8, flickr, focus, hawk, infinity, lens, macro, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shot, shots, smc
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
Ideas on diffusing the onboard flash of the Q? Tonto Pentax Q 28 05-19-2013 11:46 AM
Pentax Q lenses tested by Photozone Mistral75 Pentax Q 9 11-16-2011 12:11 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Could Pentax sell you on the Q if they had better lenses? devorama Pentax Compact Cameras 17 06-29-2011 09:34 PM
All times are GMT -7. The time now is 04:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
