11-21-2013, 07:55 AM   #571
hnikesch's Avatar
Chart updated
11-21-2013, 08:47 PM   #572
crewl1's Avatar
QuoteOriginally posted by hnikesch Quote
Chart updated
Thanks Hans.
11-22-2013, 06:15 PM   #573
AnalogMan's Avatar
Minolta Maxum AF 50mm f1.7
Just received my Fotodiox AF-P/Q for Minolta A mount lenses. The first one that I tried was the Minolta Maxum AF 50mm f1.7 (22) I believe that works out to about a 275mm
Some shots - It was a dark/overcast day
ISO 400, 1/500 sec, approx f2
ISO 200, 1/800 sec, approx f1.7
ISO 200, 1/50 sec, approx f1.7
Mike
11-24-2013, 11:18 AM   #574
hnikesch's Avatar
Chart updated, AnalogMan (Mike) would you please add some info to your post like aperture used, ISO etc...
Thanks
11-24-2013, 11:35 AM   #575
AnalogMan's Avatar
Sorry Hans! I guess I got so excited that forgot to put down the numbers! I will correct that!
Mike
11-24-2013, 12:03 PM   #576
AnalogMan's Avatar
Numbers are in!
Mike
11-24-2013, 02:29 PM   #577
hnikesch's Avatar
QuoteOriginally posted by AnalogMan Quote
Numbers are in!
Mike
You might want to play with apertures a little most of the tested lenses work best at about f5.6 or abouts
11-24-2013, 02:53 PM   #578
AnalogMan's Avatar
Good advice! I'll do some more testing when I get the chance. It was about 35 degrees that day with a wind chill in the middle 20's so I didn't take much time with my shots...BRRRRR!!! Also, the Fotodiox adaptor doesn't have any f-stop markings so I kinda guess what the aperture opening is...
Mike
12-06-2013, 05:58 AM   #579
arnold's Avatar
QuoteOriginally posted by p38arover Quote
Second with adapter and my DA* 60-250mm at 250mm.
That really pulled in that pole. Well done.
12-11-2013, 12:14 PM - 1 Like   #580
Pentax q and canon mp-e65
Its a hoverfly from behind and very short dof so just the antenna arista in focus
f2,8
1/500
iso 125
Kindly bjorsa
12-11-2013, 07:05 PM   #581
Bjorsa, now thats major macro! Very difficult shooting at this magnification. Well done. The Canon does 1-5X on a dslr. Was this at the minimum or maximm lens magnification? Your lens rocks with the Q.
thanks
barondla
12-12-2013, 03:47 AM   #582
Thanks barondla !
This shot was at 1* so around 3,3:1 the problem is that you cant change the aperture on canon lenses so you have to use 2,8 all the time
with the mp-e65 if you dont make som homemade aperture adapter .
Kindly bjorsa
12-12-2013, 04:19 AM   #583
That is a lot of magnification. Very hard to even find the subject. The slightest move misses the subject or changes focus. Great job.
I am working on a gadget to help aim my Olympus OM 20mm macro. The OM works in a Similar mag range. Such a narrow field of view. I will post pics when it is finished.
Yeah, the Canon motorized aperture is a pain when adapted to other cameras. There is a way to use different apertures. Put the lens on a Canon EOS body, select aperture you want, remove the lens without turning off camera. Aperture motor stays at that opening! Means carrying a big camera in the field ( though the M body should work). Have seen a few third party adapters that have a mechanical aperture built in. None for Q yet. You shoot my kind of photography- extreme.
Post more macros
thanks
barondla
12-12-2013, 05:04 AM   #584
That trick dosent work on my canon 50d and mp-e 65 I have already tried it before but I will try it on my other canon lenses and see if it works on them.
Sounds interesting about your olympus om 20 macro and looking forward to see some shot with it when you fix that gadget .
Here is a shot of a flyeye with pentax q and a homemade lens and the image is around 0,2-0,3 mm wide and I did stack 3 shots to get some dof
1/13
iso 125
flash
macrorail
Kindly bjorsa
12-12-2013, 10:26 AM   #585
crewl1's Avatar
QuoteOriginally posted by bjorsa Quote
1/13
iso 125
flash
macrorail
Kindly bjorsa
Whoah that is like an electron microscope but in color!
200mm, 50mm, adapter, auto, camera, f1.8, f2.8, flickr, focus, hawk, infinity, lens, macro, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shot, shots, smc
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
Ideas on diffusing the onboard flash of the Q? Tonto Pentax Q 28 05-19-2013 11:46 AM
Pentax Q lenses tested by Photozone Mistral75 Pentax Q 9 11-16-2011 12:11 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Could Pentax sell you on the Q if they had better lenses? devorama Pentax Compact Cameras 17 06-29-2011 09:34 PM
All times are GMT -7. The time now is 07:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
