02-15-2014, 01:07 AM   #616
VisualDarkness's Avatar
SMC Pentax-DA 14mm F2.8 ED [IF]
I tested mounting my new DA 14mm F2.8 with my genuine Q-K adapter, despite it being pretty dumb range (clashes with Q lenses) for adapting such a lens. Though I must say that it surprised me with sharpness and CA as it's considered a weaker lens in the DA lineup.
F2.8
~F3.2
~F4
~F4.8
~F5.6
~F6.7 (DIffraction softness occurs)
~F8
~F22 (really soft due to diffraction)
02-15-2014, 07:23 PM   #617
Otis Memorial Pentaxian
q with qk adapter sigma 500 with sigma 1.4x adapter
02-16-2014, 05:51 AM   #618
baro-nite's Avatar
QuoteOriginally posted by pearsaab Quote
Wow, amazing detail for such reach. I dare say there's a bit of motion blur in the head and wings; never a surprise with birds at 1/30s. What aperture setting on the adapter?
02-16-2014, 12:20 PM   #619
QuoteOriginally posted by baro-nite Quote
thanks...I usually set it at 0.5, 1 tops
02-16-2014, 07:00 PM   #620
Shanti's Avatar
Birds with DA*300 & Q
Q with aperture control adapter,ISO 800,F4.5, sec,high winds & hard to get accurate focus,but not so bad for conditions
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
02-18-2014, 06:41 AM   #621
Lurch's Avatar
Sigma 50mm 2.8 EX Macro
Using a very cheap and nasty adaptor
With a bit of a bump in contrast in LR:
Similar shot on 'Bold Monochrome'
To give you an idea, thats the '10' from an Australian 10c piece; so pretty good I thought.
02-18-2014, 06:53 AM   #622
baro-nite's Avatar
QuoteOriginally posted by Lurch Quote
Looks excellent. Do you know the magnification for that shot?
02-18-2014, 07:00 AM   #623
Lurch's Avatar
I honestly dont know; but it'd have to be close to 1:1
02-18-2014, 09:43 AM   #624
crewl1's Avatar
Updated index, thanks for your contributions.
02-18-2014, 10:07 PM   #625
Lurch's Avatar
If its worth anything to anyone; it actually make a good little set up. Because the lens is so light to begin with its no where near as unbalanced as some other lenses mounted to a Q
02-21-2014, 07:39 PM   #626
Q + Sakar Auto MC 135mm 1:2.5, and Fotodiox MD-PQ adapter. I forgot to remove the lens cap before the pic. This lens has a MFD of 1.5m, and a macro ring that goes from 1:7 down to 1:4. Minolta MD mount. It is clear from the first example photo that my focusing technique using the screen in bright sunlight needs some work. The white focus peaking highlights looked like I had it spot on. The leaves in the second are OOF because there was quite a stiff breeze blowing, and they were whipping back and forth. I guess that could have affected the tree limb, too.
Tony
02-25-2014, 03:40 AM   #627
GUB
GUB's Avatar
LPL 75mm f3.5 Enlarger lens.
As with most enlarger lens this one has a 39mm mount. To adapt it I bonded a female M42 thread onto a D-mount / Q adapter to create a minimum length adapter. I then mounted a 16mm helicoid tube and mounted the lens on the front of it with another homemade adapter (39mm female to 42male). A proper 39/42 adapter and a 12-17mm helicoid are in the mail and will make infinity focus possible for shorter focal length enlarger lens. This 75mm lens appears to be uncoated and this is noticeable in use. The images here were taken without a lens hood. I think this lens has real potential for close up work. Images are taken at f5.6 ISO125
I saved as JPG , worked the colour curve and sharpened a little. I cut and pasted a section of the original unedited image into the bottom of the images to demonstrate the lack of contrast of the native image.
PENTAX Q  Photo
PENTAX Q  Photo
02-25-2014, 04:06 AM   #628
GUB
GUB's Avatar
Travegar 50mm f3.5 Enlarger lens.
This lens came off a common old UPA Eastern Bloc suitcase enlarger from back in the 1970s-80s. It has an oddball mount thread (about 32mm). The lens has a little haze on it that has resisted cleaning so far. The images show this. It is not a high tech lens--- with 2 elements up front and only one at the back, but strangely it has a 12 leaved iris. I had to home build an adapter for it. To adapt it I bonded a female M42 thread onto a D-mount / Q adapter to create a minimum length adapter. I then mounted a 16mm helicoid tube and mounted the lens on the front of it with another homemade adapter. ( I still had the enlarger mount.)
The images are at f5.6 ISO125. Saved as JPG.
I colour curved the result and sharpened a little, but have also cut and pasted a section of the original image onto the result.
Overall I think this lens would be passable if I can remove the haze.
PENTAX Q  Photo
PENTAX Q  Photo
02-25-2014, 12:12 PM   #629
crewl1's Avatar
Very cool work with those enlarger lenses, you must post a pic of the adapter mod.
Thanks all for your contributions, index is now updated.
02-25-2014, 01:05 PM   #630
GUB
GUB's Avatar
QuoteOriginally posted by crewl1 Quote
Here is an exploded view photo of the setup to use enlarger lens. The need for the helicoid tube is to provide focussing as of course enlarger lens have no focus movement. So the issue is to get the arrangement short enuf to achieve infinity focus. That is easy enough with the 75mm lens and if fact it needs the short extension tube included. But the other 50mm lens I wish to use won't quite get to infinity so I am buying a short (12mm) Helicoid. The camera mount is a D mount / Q adapter with the female thread of an extension tube bonded to it. Having this short as possible is critical. The Travegar lens with its mount is in the foreground. Because of the way its adapted mount is recessed it achieves infinity on this set up.
PENTAX K-30  Photo
200mm, 50mm, adapter, auto, camera, f1.8, f2.8, flickr, focus, hawk, infinity, lens, macro, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shot, shots, smc
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
Ideas on diffusing the onboard flash of the Q? Tonto Pentax Q 28 05-19-2013 11:46 AM
Pentax Q lenses tested by Photozone Mistral75 Pentax Q 9 11-16-2011 12:11 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Could Pentax sell you on the Q if they had better lenses? devorama Pentax Compact Cameras 17 06-29-2011 09:34 PM
All times are GMT -7. The time now is 07:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
