Originally posted by GUB Here is an exploded view photo of the setup to use enlarger lens. The need for the helicoid tube is to provide focussing as of course enlarger lens have no focus movement. So the issue is to get the arrangement short enuf to achieve infinity focus. That is easy enough with the 75mm lens and if fact it needs the short extension tube included. But the other 50mm lens I wish to use won't quite get to infinity so I am buying a short (12mm) Helicoid. The camera mount is a D mount / Q adapter with the female thread of an extension tube bonded to it. Having this short as possible is critical. The Travegar lens with its mount is in the foreground. Because of the way its adapted mount is recessed it achieves infinity on this set up.
Wow that looks like it took some engineering talent to figure out. Nice work.
---------- Post added 02-25-14 at 05:29 PM ----------
Originally posted by Feline What setting are best for adapted lenses or is it best to leave Q on auto?
Thank you,
Felix
Nice shot. I shoot in M mode so I can control the shutter speed and ISO myself.
The aperture can be controlled by the lens or the adapter depending on type.
Sweet spot is usually trial and error and I would not leave it up to the camera in auto to figure it right.
