05-21-2014, 07:41 PM   #721
Carl Zeiss on Q10
Carl Zeiss 32mm lens I removed from a scrapped microfiche machine, adapted to the Q. Macro only.
Jacob
PENTAX Q10  Photo
05-21-2014, 09:36 PM   #722
Lowell Goudge's Avatar
QuoteOriginally posted by jacobsr Quote
Jacob
Do you know what mount this is.? Seems like a nice lens
05-21-2014, 11:18 PM   #723
Carl Zeiss Lens
Oh I love this lens, to me is priceless. the colors are deeper and the bokeh is just beautiful. But I would think this lens is very rare, it was designed specifically for old industrial microfiche machines in the 1980's.
When computer archiving arrived they junked the machines. And when I saw Carl Zeiss written on the lens I just had to remove it from the machine.
So I don't know what kind mount it is. The lens is small (about the size of 110 24mm lens). I'ts a screw mount with a ring nut at the end ot it. It can be used on K mount or any SLR mount. I just drill a hole on the body cap for the lens and tighten the nut. For the Q I found a bottle cap that fits the 110 adapter and drill the hole in the cap.
Jacob
05-21-2014, 11:41 PM   #724
"Night Out" - taken with Wollensak 13mm f/1.9 at f/1.9 and 3200 iso. I like this len because it has focus ring.
05-21-2014, 11:50 PM   #725
Kiwi Pentaxian
NZ_Ross's Avatar
Oh I love this lens, to me is priceless. the colors are deeper and the bokeh is just beautiful. But I would think this lens is very rare, it was designed specifically for old industrial microfiche machines (1970's).
Jacob
Hi Jacob, it sounds like a really interesting and unique lens - are you able to post a photo of the lens, I would be interested in seeing what it looks like.
Thanks - Ross
05-22-2014, 10:40 PM - 2 Likes   #726
Made of metal. It has aperture control, but no focusing ring. Sorry about the poor lighting.
Canon PowerShot SX150 IS  Photo
05-22-2014, 11:36 PM   #727
Kiwi Pentaxian
NZ_Ross's Avatar
Thanks for posting the photos - that is quite a unique lens
Well done rescuing it and mounting it on a Q
05-23-2014, 02:59 AM   #728
Pentax/Cosmicar 8-48mm f/1.0 on Pentax using C-to-D mount. Len is a C-mount version. This len version I have have auto-aperture control so I uncovered the cover and pull out the auto-aperture control and I can manually control aperture but I almost always shoot it wide open.
SM-N900T  Photo
E-PL5  Photo
05-23-2014, 03:09 AM   #729
Here is a test shot on its widest end of the Pentax/Cosmicar 8-48mm f/1.0 at 8mm at night light
PENTAX Q  Photo
05-23-2014, 01:48 PM   #730
daylight low light picture test of the Pentax/Cosmicar 8-48mm f/1.0 at widest setting
PENTAX Q  Photo
05-23-2014, 08:04 PM   #731
Kodak Ektanar Len 50mm f/2.8 mounted on Nikon body cap mounted on AI-to-C adapter. Picture taken with Pentax Q + Cine-nikkor 13mm f/1.9. This len was on 35mm camera.
05-23-2014, 10:45 PM - 1 Like   #732
It's just a weed, but Carl Zeiss and Q10 can make it look pretty.
PENTAX Q10  Photo
05-24-2014, 06:57 AM   #733
Fujinon TV Zoom 12.5-75mm f/1.4 C-mount on Pentax Q using C-to-D adapter. Len is a C-mount.There is no vignette (considering the equivalent 35mm-210mm focal range, which is great for mild wide angle to mild tele), and the len is really sharp. The len comes with auto-iris so you will need to remove the wires
05-25-2014, 04:07 AM   #734
Pentax Q with DA 10-17mm FishEye
hi all. i have the photodiax adapter with lock<->open slider and just played around with DA10-17 fish eye and M-50mm 1.7.
both looks "ok", here i give one with the fish eye (at 17mm, handheld at room lighting, iso 400) but there are couples questions i want to ask:
1. on the adapter i have to keep the slider to "open" is that correct? if i move slightly to the lock direction the picture will be darker.
2. has anyone dare to bring Q and only pk lens (or lenses) for travelling/holiday? or too risky and better put the original Q lense (i only have the number 1 lens)?
if so please recommend which one i have to bring:
M-50mm 1.7
DAL 18-55mm kit
DA 18-250mm
DA 10-17mm
Sigma 17-70mm 2.8-4.5
thanks
PENTAX Q  Photo
05-26-2014, 10:31 PM   #735
QuoteOriginally posted by erwinsie Quote
M-50mm 1.7
DAL 18-55mm kit
DA 18-250mm
DA 10-17mm
thanks
1) the slider is to control the aperture, darker means closed. Normally you mount open and then you might close just a little bit to get more depth of field. Closing a lot (going to lock) will probably ruin the pictures on the Q, however I guess we are just waiting till someone uses this creatively to create better art then others.
2) It will be easier to work with the 01, seeing what it can do, I would take it. It depends what you want to do, for the others:
10-17 is still OK for walk around, covering the normal range in 35mm FOV equivalent.
Above 17 you will be in telephoto, so the subjects and the technique changes, you will need to keep your camera more still and go for small subjects on larger distance.
200mm, 50mm, adapter, auto, camera, f1.8, f2.8, flickr, focus, hawk, infinity, lens, macro, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shot, shots, smc
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
Ideas on diffusing the onboard flash of the Q? Tonto Pentax Q 28 05-19-2013 11:46 AM
Pentax Q lenses tested by Photozone Mistral75 Pentax Q 9 11-16-2011 12:11 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Could Pentax sell you on the Q if they had better lenses? devorama Pentax Compact Cameras 17 06-29-2011 09:34 PM
All times are GMT -7. The time now is 02:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
