05-27-2014, 12:05 AM   #736
Taken with Pentax TV Zoom 12.5-75mm f/1.4. It is a C-mount len
05-27-2014, 06:11 AM   #737
CCTV Avenir 12mm f/1,2 (c-mount) on Pentax Q7
f/1,2
f/4
VS. Pentax 02 f/4:
Samples with Avenir 12mm f/1,2:
f/1,2
f/1,2
05-27-2014, 07:26 AM   #738
hnikesch's Avatar
Chart updated, cunesk8, rendition, jacobsr, guys could you please add some additional mount info to your posts, in some cases the info is lacking if it's a C, CS, D or other mount and what was required to get it working. In the chart all are listed as "other mount" but if someone is looking to adapt a lens the additional info would be helpful
Thanks
05-27-2014, 10:04 AM   #739
crewl1's Avatar
Thanks for keeping up the index Hans, I've been a bit busy lately.
05-27-2014, 11:25 AM   #740
Lowell Goudge's Avatar
QuoteOriginally posted by crewl1 Quote
The last 2 days has kept me busy too cross linking this to the sample image archive
05-28-2014, 11:35 PM   #741
Carl Zeiss adapter to the Q
Well I don't know the mount of my lens. It's a 32mm Carl Zeiss lens that was in either 3M or ABDick/scott Microfiche or Record Processing machine. I can't recall for sure. Most of the machines were scrapped and probably long gone. But the lens could have been used in many other applications so good luck finding this type of the lens.
The lens diameter is 2 centimeters (.78"). The rear of the lens is threaded and it comes with ring type nut that screws into the end of the lens.
Since I don't have any of the (C) or (D) mounts I can't tell you if this lens can be mounted on them. What is the diameter of these mount? I like to know myself.
Best use is on Pentax DSLR camera body cap. The body cap can also be used on the K mount adapter to the Q.
All you have do is drill a hole 2 centimeters in diameter in the body cap, insert the lens from one end and screw-in the ring nut from the back of the lens.
It won't work directly on the Q because the sensor is very close to the lens mount, It will definitely touch. and considering the focal length you will need at least 1.25 of an inch clearance from the sensor.
If you're using 110 to Q adapter, you have to find a cap or something that fits the adapter, or have one made. I found a cap that goes on Walgreen pills container. The cap is shaped like a hat so it had depth for the lens mount and it fits the 110 adapter. It works but not very secure. So I'm always looking.
I'm sorry if the explanation is not clear, English is not even my second but third language. I will gladly answer any questions.. But it's easy because if I can do it, anybody can.
Jacob
05-29-2014, 06:04 AM   #742
hnikesch's Avatar
QuoteOriginally posted by jacobsr Quote
Jacob
Thanks for the info, it was quite interesting and I am sure it will provide others with ideas on adapting other lenses.
The link below provides info into C and D mount and most others. The flange distance info is the most important but if you click on the mount in the chart it will also provide thread sizes.
Thanks again for your input
Thanks also to cunesk8, & rendition for the additional info
http://en.wikipedia.org/wiki/Flange_focal_distance
05-29-2014, 06:03 PM   #743
Rainbow 3.5mm f/1.6 . Sharp image and much brighter than Pentax's len. No vignette wide open. Give about 19.6mm field of view. Len is C-mount and can be used on Pentax with C-to-D adapter.
05-29-2014, 08:53 PM   #744
dms
Pentax super-takumar 35mm f/3.5 on Q w/ Pentax K-Q Adapter
Informal testing so far my 35mm Takumar is significantly better (at infinity) than 50mm f/4 (macro K)** and Vivitar 100mm f/3.5 (macro PKA)**.
The following are 35mm Takumar, on original Q, w/ the Pentax K to Q adapter. The lens aperture was used.
-- 100% crops of f/3.5, f/5.6, and f/8
-- the full view at f/5.6
Used heavy tripod w/ 2 second timer. Minor exposure adjustment to the three pictures (to make exposure essentially identical), and then convert from Raw to JPG. No other pp.
** Ignore my statement about Pentax (K) 50mm f/4 and Vivitar 100mm f/3.5. I was comparing several shots all w/ lens wide open, and did not realize it.
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
Last edited by dms; 06-02-2014 at 09:23 PM. Reason: Revise Statement about Pentax 50mm and Vivitar 100mm lens.
05-29-2014, 09:07 PM   #745
Flange Focal Distance
QuoteOriginally posted by hnikesch Quote
Flange focal distance - Wikipedia, the free encyclopedia
Oh yes the flange distance is crucial, and thanks for the Wikipedia link. Great info.
I did some measuring on this 32mm Carl Zeiss lens. The flange focal distance is about 17 to 18mm.
According to Wikipedia it might work on C mount Bell & Howell. If the diameter and thread match.
But then the focus point will be about 2.5 feet away, not a real macro, and with no focusing ring is kind useless. You need more space from lens to sensor, and like I said it's best to use K to Q mount. It will work beautifully.
Jacob
06-04-2014, 06:53 PM   #746
How to mount CS-len onto Pentax Q. You will need a Pentax Q's HARD PLASTIC body cap (being sold on ebay) and you will need to cut/drill the entire red-line diameter. CS-type lens WILL NOT WORK with C-to-D adapter because the focus distance is shorter. Once you cut it, add superglue to attach the body cap to the len's body.Shown here is the $11 Ultrak 3.5-8mm f/1.4 mounted on the Pentax Q. It can do close and infinity focuses on both zoom end. It has 19.6mm to 44.8mm on full frame, essentially makes it a Wide-angle zoom len. Again, notice this is a CS-mount len, not the regular C-mount len
Picture samples of Ultrak 3.5mm-8mm f/1.4. Overall vignette on 3.5mm and no vignette on 8mm and it has less constrasty color when taking in-camera. I attached some sample photos. Recommend to be used with Bold Monochrome mode in-camera, otherwise you will need to do some post-processing with color to bring out the contrast. Not bad for a cheap zoom len though
3.5mm unedited
3.5mm edit
8mm unedit
8mm edited
in-camera bold monochrome
06-07-2014, 09:13 AM   #747
I am a new Pentax Q owner from Jamaica for a week now. Got the body off of AMAZON for $109.99 and the Fujian 50mm f1.4 cctv lens from ebay for $33.99. Nice camera good features but man that crop factor is hard to handle sometimes and work best at other times. I manage a facebook page "Jamaica Wi Love" and mainly take pictures of Jamaican culture and post. I now need a good enough wide c-mount lens for my Q that has good sharpness. The 50mm is not very sharp wide open and has some haze but stopped down a bit and it looks sharper. I was looking at the "ABL Corp LENS-04 4mm Lens" on ebay that will be a 22.4mm on the Q. Anyone tried it or have better suggestions?
06-07-2014, 02:29 PM   #748
Pentax Q + D-mount Arco-Cine 13mm f/1.4
06-07-2014, 10:39 PM   #749
"Framed" - Taken with Pentax Q + D-mount Arco-cine 6.5mm f/1.4
06-08-2014, 10:52 PM   #750
QuoteOriginally posted by rendition Quote
Hey rendition, where do you get all these lenses?
cool stuff. Lots of lenses lots of fun.
JR
200mm, 50mm, adapter, auto, camera, f1.8, f2.8, flickr, focus, hawk, infinity, lens, macro, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shot, shots, smc
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
Ideas on diffusing the onboard flash of the Q? Tonto Pentax Q 28 05-19-2013 11:46 AM
Pentax Q lenses tested by Photozone Mistral75 Pentax Q 9 11-16-2011 12:11 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Could Pentax sell you on the Q if they had better lenses? devorama Pentax Compact Cameras 17 06-29-2011 09:34 PM
All times are GMT -7. The time now is 07:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
