06-14-2014, 05:45 PM - 1 Like   #766
C-mount TV 200mm f/4 canon modified to work on both m43 and pentax Q
From this
to this
to this
to this
Sample shot near 1120mm handheld
Another sample shot
More infor at https://www.facebook.com/media/set/?set=a.1408342299454595.1073741855.100008...1
06-15-2014, 03:32 AM   #767
GUB
GUB's Avatar
QuoteOriginally posted by jacobsr Quote
You can purchase these washers from any hardware store for about .50 to .70 cents
WHATTTTT !!!!----- I get a hundred ringbinder rings for $5 -- thats 5c a ring -- you are blowing money man!!!
Naa it is a great idea and easily removable. Great comparison photos.
One comment tho ( and sort of the same as Transits) but to do with the depth of rubber material. Your iris is thick enough that there is an extra surface to reflect light compared to the ringbinder ring. Experiment with buckling the iris away from the lens and the inside of the iris orifice is then out of sight of the lens.
This could increase contrast and change the stop slightly.
It could also incur vignetting.
Great work
Baz
06-15-2014, 06:34 AM - 1 Like   #768
Great find and mod, rendition. Never dreamed they made such long lenses in that mount. Cool. You are pushing the Q fun factor to the max.
thanks for sharing
barondla
06-16-2014, 07:10 AM   #769
hnikesch's Avatar
Chart updated
06-16-2014, 07:28 PM   #770
GUB
QuoteOriginally posted by GUB Quote
Great work
Baz
Yes, but you buy one washer and that's it, set it and forget it.
Good point about the thickness of the iris, I tried your suggestion by buckling it away from the lens, I really didn't notice any difference in the test shots. Maybe some matt paint will help.
Thank you for your suggestions, and thanks again for your posts, after all, you gave me this idea.
Regards
Jacob
06-26-2014, 02:51 PM   #771
Converted CS-mount Cosmicar 6mm f/1.4. Image is sharp, small size and easy to carry around. ~35mm field of view
Sample picture taken at f/1.4
06-26-2014, 05:45 PM   #772
QuoteOriginally posted by rendition Quote
F1.4 and 35mm FOV? Wow! Can you change the aperture setting or are you stuck with f1.4?
Anyhow it looks sharp. This is a very nice lens and it looks good on the Q.
Jacob
06-27-2014, 12:04 AM   #773
Jacob
Hi Jacob:
You can change the aperture (as there is an aperture ring) up to f/22 but there's no marking of f-stop. Cosmicar brand tend to be sharp. Anyhow I bought the len for $6.5 and paid $5.5 shipping. 35mmm is a good field of view, not too wide as the Rainbow 3.5mm which is ~20mm field of view. Again as noted, this len is a CS-mount and you will need a Pentax Q body cap and make an opening hole to mount the len.
07-03-2014, 03:10 PM   #774
D-mount Arco Cine 6.5mm f/1.4 nearly no vignette on Q and a psychedelic distortion
07-03-2014, 10:47 PM - 2 Likes   #775
Pentax Q + Modified/Converted Keystone K-1 turret D-mount: Keystone Elgeet 13mm f/1.8, Keystone Elgeet 7.5mm f/1.8, Keystone Elgeet 25mm f/1.8
Images shot with this len
07-04-2014, 01:14 AM - 1 Like   #776
Oh boy! Isn't there a gear porn section somewhere? Or perhaps start a thread: Gear Qorn ;-)
07-04-2014, 07:05 PM - 1 Like   #777
Amazing modification for the Q! Never expected to see the Q with a turret full of lenses. It is like a glass bouquet. Rendition, you have multipled the Q fun factor by 3. Bet everyone gives this a double take when you are out shooting. Love it.
thanks for sharing
barondla
07-06-2014, 04:26 AM   #778
QuoteOriginally posted by eyeswideshut Quote
QuoteOriginally posted by barondla Quote
thanks for sharing
barondla
Thanks guys. I am having a lot of fun converting old lens and with Q. Also, here is my recent custom converted Chimeric Pandora-6 (head is Russian 8mm movie len Pandora-6, tail is Russian 8mm movie len Meteor-8) mounted on Pentax Q. Len's marking indicated 9-25mm f/1.8 but since it is a combined len, the actual focal length is 15-35mm. It makes great vintage footage on Q.
Len shows chromatic aberration under bright day light. Here's an indoor test shot during the day
07-06-2014, 11:30 PM - 1 Like   #779
Frankar ~7mm-35mm D-mount made of various len parts, mainly from meteor-8M and Kodak Ektanon parts.I managed to lengthening the focusing distant and able to create a D-mount also. It showed sharp image center. Screws are for zoom handling
Rear View
07-07-2014, 08:24 AM - 1 Like   #780
Jens Lyn IV's Avatar
Frankar
Ha, Frankenstein's lens indeed!
200mm, 50mm, adapter, auto, camera, f1.8, f2.8, flickr, focus, hawk, infinity, lens, macro, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shot, shots, smc
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
Ideas on diffusing the onboard flash of the Q? Tonto Pentax Q 28 05-19-2013 11:46 AM
Pentax Q lenses tested by Photozone Mistral75 Pentax Q 9 11-16-2011 12:11 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Could Pentax sell you on the Q if they had better lenses? devorama Pentax Compact Cameras 17 06-29-2011 09:34 PM
All times are GMT -7. The time now is 07:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
