08-15-2014, 10:14 AM   #826
Pentax 110 50mm F2.8 stopped down
Moving on from the 18mm lens I tried the 50mm lens. This was also taken hand held at 1/100th second (a bit ambitious given the 280mm 35mm equivalent!). The lens was stopped down using the 'ring binder reinforcement' method and mounted to a cheap eBay PTX 110 - P/Q adapter. The picture is straight out of the camera but resized.
PENTAX Q  Photo
08-15-2014, 10:17 AM   #827
Pentax 110 24mm F2.8 stopped down
The last of my collection of Pentax 110 lenses is the 24mm F2.8. As with the others, this was taken hand held at 1/100th second. The lens was stopped down using the 'ring binder reinforcement' method and mounted to a cheap eBay PTX 110 - P/Q adapter. The picture is straight out of the camera but resized.
PENTAX Q  Photo
08-15-2014, 12:46 PM   #828
VisualDarkness's Avatar
QuoteOriginally posted by 35millimeter Quote
The other ones looks amazing but this doesn't look stopped down enough.
08-15-2014, 12:51 PM   #829
QuoteOriginally posted by VisualDarkness Quote
Thanks. I used the same ring binder reinforcement hoop things on each lens. To be fair I suspect there may be an element of camera shake using that 50mm lens hand held at 1/100th, and I think there will be less depth of field with the 50mm too.
08-15-2014, 01:48 PM   #830
Yeah, but I still think it would be better stopped down just slightly more, quite typical for older tele lenses.
08-15-2014, 01:52 PM   #831
GUB
GUB's Avatar
I think that will be the difference.
nice images.Oh and remember I have pped my results.
Isn't it refreshing to use the simplicity of these 110s.
08-16-2014, 03:31 PM   #832
Ricoh XR 50mm 1:2 / OEM adapter
Fairly decent at 5.6. Didn't reset the shake number so it says 400mm in error.
PENTAX Q  Photo
PENTAX Q  Photo
08-18-2014, 02:23 PM - 1 Like   #833
Russian LOMO OKC3-10-1 10mm f/1.8 (T/2.1) modding // cinema len
Sample images
08-18-2014, 03:29 PM - 1 Like   #834
crewl1's Avatar
Wha! That lizard is cannibalizing a baby! Nice work on that lens.
08-19-2014, 07:05 AM   #835
Instead of wasting time hacking an old film movie camera to death to get the lens out so we can shove it through a hole we poked in a plastic body cap and try to take a photo with it, I want to know when someone is going to take a handful of sand and melt it down and pour it into a mold and polish it on a rock and make their own lens so they can duct tape it to the front of a Q and take a photo with that...
08-19-2014, 10:00 AM   #836
Panasonic 4mm f/0.75
Sample images
at f/0.75
at f/1
at f/1.4
daylight sample at f/1.4
08-19-2014, 01:10 PM - 1 Like   #837
You are finding some nice lenses
08-19-2014, 02:01 PM   #838
crewl1's Avatar
QuoteOriginally posted by oscaletrains Quote
Check the index it may have already been done. I remember a toilet paper roll being involved somewhere.
08-19-2014, 02:20 PM   #839
QuoteOriginally posted by crewl1 Quote
You mean the guy that was stupid enough to make a macro lens with a bad lens, paper roll, tape and rubber band? Oh, now I remember, it may have been me.
08-19-2014, 06:03 PM   #840
Canon EF 100mm f2.8 macro
Well, I did it, sort of...The iris adapter now has a Canon receiver and a Pentax K mount. I could have used the $125 Canon to Q adapter on Ebay, but then I could not ever put the lens on a regular size Pentax camera.
Photo 1 is the iris adapter with the 4/3 mount that I needed to replace with a K
Photo 2 is the 4/3 mount removed, the K adapter is on the right with the remains of the donor lens in the background
Photo 3 is machining the K adapter to fit
Photo 4 is the completed unit
PENTAX Q10  Photo
PENTAX Q10  Photo
PENTAX Q10  Photo
200mm, 50mm, adapter, auto, camera, f1.8, f2.8, flickr, focus, hawk, infinity, lens, macro, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shot, shots, smc
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
Ideas on diffusing the onboard flash of the Q? Tonto Pentax Q 28 05-19-2013 11:46 AM
Pentax Q lenses tested by Photozone Mistral75 Pentax Q 9 11-16-2011 12:11 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Could Pentax sell you on the Q if they had better lenses? devorama Pentax Compact Cameras 17 06-29-2011 09:34 PM
All times are GMT -7. The time now is 07:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
