Originally posted by Piotrek K
The original Q. Nikkor EL-Nikkor 50/2.8 probably at 5.6 (this is enlarger lens, I have older version). Setup: M39 to M42 adpater, M42 variable extension ring, M42 - K adapter, homemade K to Q adapter, 2 small cheap chinese video led lamps.
What great results. I had heard that the EL nikkors enlarger lenses are pretty good.
How low a profile have you achieved with your custom Q to 42 adapter.
The best I have achieved is this setup. I took a D mount to Q adapter and bounded it to the internal end of a non infinity PK to M42 adapter.
I now can achieve infinity focus with 50mm enlarger lens compared to the adapter I was using in my photo on post 630
https://www.pentaxforums.com/forums/136-pentax-q/209474-adapted-lenses-tested...ml#post2716126
So from left to right:
Custom adapter. ( The relatively small D mount hole acts nicely as a baffle.)
A 40.5mm ir-uv cut taken out of its mount and located with the rubber washer.( There is a modest image gain from the ir-uv cut filter but its main purpose is to keep the sensor enclosed while I mess around changing lenses)
Then a standard Pentax M42 helicoid
And finally a 39 to 42 adapter.
This setup is great also with M42 lenses giving a built in closeup ability.
In the foreground is a 110 mount taken from a camera body and bonded into a custom washer that slips down the top of the helicoid and sits on a shelf about 15mm inside . This gives me closeup ability with the 18 and 24 110s. The 50 is too big.
The black washer acts as another baffle.
The second picture is a close up of the adapter.
