10-13-2014, 06:57 PM - 1 Like   #901
Otis Memorial Pentaxian
Pentax Q with QK adapter setting 1 sigma 500mm 4.5ex
versus Q7 with same
10-14-2014, 12:39 AM   #902
QuoteOriginally posted by pearsaab Quote
versus Q7 with same
Dang, that is some insane focal range...
10-14-2014, 07:10 AM   #903
crewl1's Avatar
They both look awesome, Amy.
10-14-2014, 08:53 AM   #904
QuoteOriginally posted by rendition Quote
QuoteOriginally posted by crewl1 Quote
thanks guys!!
10-14-2014, 08:50 PM   #905
Wollensak Raptar 13mm f/1.2 C-mount. Len is solid, heavy, big, and buttery sharp wide open at f/1.2. Highly recommend as a portrait len for pentax Q.
Sample picture on pentax Q at f/1.2
10-15-2014, 02:16 AM   #906
GUB
GUB's Avatar
Pentax-M 50mm /1.4 on the Q (2)
I am doing the 50mm 1.4 because the existing review has had its images removed.
I kept the lens stopped down to f2 - f2.8 except the bluebell which I think was wide open.
I didn't have much luck with landscape images -- maybe someone else could show its potential there.
There seemed to be quite a lot of purple and green fringing.
I think the 50mm 1.7 had more potential but still I feel this was a nice creative lens.
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
10-15-2014, 04:05 PM - 1 Like   #907
Schneider Xenoplan 13mm f/1.9, the non-focusing version; Modified to C-mount that allows macro and infinity focusing; len original taken from a Nizo camera. Very sharp len wide open; on m43 it is 52mm FOV.
Sample pictures taken on Q, both at f/1.9
https://www.flickr.com/photos/124354192@N07/15355456030/
https://www.flickr.com/photos/124354192@N07/15359514308/
10-16-2014, 12:42 PM - 1 Like   #908
crewl1's Avatar
Rendition you are the king of modding lenses for the Q. You should do an article all about this!
(Promising to update the index this week.)
10-17-2014, 02:45 PM   #909
Switar 36mm f/1.8 d-mount +q. Very sharp len.
https://www.flickr.com/photos/124354192@N07/14938159744/
10-23-2014, 05:53 PM   #910
GUB
GUB's Avatar
Pentax-A 50mm / 1.7 on the Q (2)
The images have been removed on the first review of this lens so I thought I would put one in.
I was amazed at how much difference there was between wide open (f1.7) and one click in (f2) That would be less than half a stop wouldn't it?
The images in order of upload -- f1.7, f2, and the rest f5.6 or 8.
The iris has a noticeably serrated outline at f2 and I suspect it gives it a sweet spot for bokeh compared to the poached egg look of wide open.
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
10-23-2014, 05:58 PM   #911
mythguy9's Avatar
May I challenge some of you fanatic lens testers and adventurers to make more pinhole lenses? When I get less busy in December, I will try to make a wide angle pinhole (with hole recessed into the body) - a bit tried of normal focal length pinhole :P
10-24-2014, 12:26 PM   #912
Fujinon 2.7mm f/1.8 c-mount. High resolution 5MP-rating len that gives fisheye effect on 1'' sensor but fully cover Q/Q10/Q7/Q-S1
Sample pictures
"Pinch Me xD" - FUJINON 2.7mm f/1.8 c-mount + pentax Q
https://www.flickr.com/photos/124354192@N07/15617931885/
https://www.flickr.com/photos/124354192@N07/15622740142/
https://www.flickr.com/photos/124354192@N07/15461404530/sizes/c/
11-03-2014, 04:50 PM   #913
crewl1's Avatar
Index updated. Let me know if you see any omissions or bad links. Thanks for all the contributions folks.
11-08-2014, 01:12 AM   #914
Pentax DA 40 XS
I was deliberating if it makes sense to use this one for a Q cameras. But finally decided that it would be fine to have equivalent of 150/2.8 used on APSC with minimum focusing distance of 40 cm. For me this lens is usable starting wide open (with some fringing problems, but no problem for many subjects) and really good when closed down.
This lens looks fine on the Q!
The wide open shots:
Next ones approximately at f 4 - f5,6:
JPG’s were sharpened after resize to web size.
11-08-2014, 07:15 AM   #915
Mikesul's Avatar
The little XS looks awesome on the Q and the photos are impressive.
200mm, 50mm, adapter, auto, camera, f1.8, f2.8, flickr, focus, hawk, infinity, lens, macro, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shot, shots, smc
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
Ideas on diffusing the onboard flash of the Q? Tonto Pentax Q 28 05-19-2013 11:46 AM
Pentax Q lenses tested by Photozone Mistral75 Pentax Q 9 11-16-2011 12:11 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Could Pentax sell you on the Q if they had better lenses? devorama Pentax Compact Cameras 17 06-29-2011 09:34 PM
All times are GMT -7. The time now is 06:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
