02-02-2015, 01:54 AM   #961
GUB
GUB's Avatar
QuoteOriginally posted by murrelet Quote
No, each image was originally 4000x3000. I lined them up, full size, in Gimp. Then scaled the composite image down for uploading. Let me know if that answers your question.
Yep all answered. Impressive results. Is the yashica always distinctly warmer than the other lens?
02-02-2015, 01:54 PM   #962
murrelet's Avatar
QuoteOriginally posted by GUB Quote
I'm not entirely sure. I'll do some more testing, especially since I got the Lytar and the Kern-Paillard to do portraits (I already had the Yashinon from when my wife bought me an 8mm movie camera from an antiquing outing).
The weird thing is that I'm pretty sure I had the Q7 white balance set for "daylight" instead of "AWB" thinking that the white balance would be fixed at a specific K. But when I imported the RAW file in Lightroom, the Yashinon images were set at almost 5000K and the images from the other lenses were set at around 4000K. I'm probably not fully understanding what the camera does when setting white balance.
I have a color target so when I get around to testing, then I should have some answers.
02-03-2015, 04:48 AM   #963
Sigma 120-400 HSM OS
Here a quick example with Sigma 120-400 HSM OS - Tripod, + remote @3s - Traget is about 80-100meters
First with 02lens @15 : target is the red circle
Now with the 120-400 Wide open
Crop @ 50%
Raf
02-03-2015, 03:40 PM   #964
Transit's Avatar
QuoteOriginally posted by pacerr Quote
There's a better way - I just happened to have a trashed binocular around when the thought struck. See: 45
It's worth exploring any 1" single element.
ok thanks for that pacerr
02-04-2015, 02:34 PM   #965
CCTV Fujian 25 F/1.4
Hi
Some samples from a CCTV Fujian 25 F1.4 lens paid 20USD on Ebay with the adapter ;-) Just received it today - here are the first test
Lens is OK for the price; you will find many positive feed-backs on the web. PF is visible wide open but lens sharpness is fine @1.4.
PF disappears and sharpness increases quickly when close a little - let say by F2.0 . I've not noticed any corner darkness , so if you look for "lomo" shot you will need to add this as a filter
All shots taken wide open ( photo full size on my flickr)
1) Dof test
2- Cat 800iso
3) Bokeh Test
02-04-2015, 07:17 PM   #966
crewl1's Avatar
This weekend I will try to get the latest lenses indexed. Thanks for the contributions.
02-11-2015, 02:04 PM - 1 Like   #967
hnikesch's Avatar
Pentax Takumar (Bayonet) 135mm f2.5
The following images were shot with my Pentax Q7 the 135 seems very sharp at f5.6 and not bad wide open, all images were cropped for framing and the RAW images were processed in LR5
I recently purchased an old (1980’s) vintage 135mm lens to adapt to my Pentax Q7 camera with a crop factor of 4.7 and wide open an aperture of f2.5 can come in handy. So the 135 has the effective focal length of 635mm when mounted to the Q7. The following images were shot hand held.
Larry if you don't get to it I will also try for an update this weekend
Hans
02-11-2015, 03:21 PM   #968
Impressive hnikesch. You are the king of handholding Q adapted tele lenses. These are striking images.
thanks
barondla
02-11-2015, 04:02 PM   #969
drougge's Avatar
QuoteOriginally posted by hnikesch Quote
I recently purchased an old (1960’s) vintage 135mm lens
While that may well be true, I assume you're talking about the lens in your post title. And that's an 80's lens.
02-11-2015, 05:29 PM   #970
Pioneer's Avatar
Great photographs hnikesch. Thanks for sharing.
02-11-2015, 06:28 PM   #971
Very impressive.......great job!
02-11-2015, 10:12 PM   #972
crewl1's Avatar
QuoteOriginally posted by rafa75 Quote
Hi
1) Dof test
2- Cat 800iso
3) Bokeh Test
Rafa which camera are you using so I can add to the index?
02-11-2015, 11:30 PM   #973
crewl1's Avatar
Index updated with latest contributions.
02-12-2015, 05:52 AM   #974
hnikesch's Avatar
QuoteOriginally posted by drougge Quote
I stand corrected, thanks, just a small brain fart on my part
Hans
02-12-2015, 10:50 AM   #975
Original Q with Mamiya Sekor 645 80mm 2.8 @5.6. 450mm eq.
200mm, 50mm, adapter, auto, camera, f1.8, f2.8, flickr, focus, hawk, infinity, lens, macro, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shot, shots, smc
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
Ideas on diffusing the onboard flash of the Q? Tonto Pentax Q 28 05-19-2013 11:46 AM
Pentax Q lenses tested by Photozone Mistral75 Pentax Q 9 11-16-2011 12:11 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Could Pentax sell you on the Q if they had better lenses? devorama Pentax Compact Cameras 17 06-29-2011 09:34 PM
All times are GMT -7. The time now is 04:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
