11-24-2015, 07:34 AM   #1021
QuoteOriginally posted by Professor Batty Quote
I don't have the faintest idea what you are talking about. My images seem to work just fine. What is BBCode? What line are you talking about?
So that your image will show here on the forum without having to click on it. On the photobucket page see "share this photo" and choose the one that says "IMG" with the 'URL' tag.
And then we can see this here, like so.
11-24-2015, 08:03 AM   #1022
I still have to click on it, and the image is smaller, even when I hit the + icon. I've never seen an image on this forum without clicking on it first. Is that a Java script?
I think my ad blocker might be disabling it.
Yeah, something in your setup (and if using mobile interface, that would be different). This thread is images top to bottom, I don't have to click on anything...
11-24-2015, 08:39 AM   #1023
crewl1's Avatar
Your post from the prior page looks fine like this:
But the one on this page does not show the image, only a link like this.
Make sure to copy the code from the box "IMG"
If you are doing it the same every time then there must be a problem elswhere.
The alternative is when writing your post, click on the icon with little picture of the mountains and in that window insert the link from the Photobucket block called "Direct" and it will be formatted properly.
11-24-2015, 09:12 AM   #1024
crewl1's Avatar
I really am at a loss. I can't wrap my head around the idea that I should post smaller images. I don't want to have to scroll through a whole screen of images.
I'll bookmark your entry so I can remember what to do. I've never had this problem on other forums.
We are not talking about requiring smaller images, just want to be able to see your images in line without having to click to go somewhere else to look.
The way the index on the first page works is if someone sees a lens they want to check out, they click the link from the index and it takes them to the post with the samples.
By placing a link to Photobucket instead of the image in the post , now you are asking the user to click another link to see the picture.
Sorry if I am not being clear, I don't know how else to explain it.
11-24-2015, 12:35 PM   #1025
baro-nite's Avatar
I'll do it your way, but it seems that I'm giving up a lot just to get a smaller image with no metadata.
You don't have to. Some users won't click the link, but it's up to you to present your images how you want.
11-29-2015, 01:06 AM   #1026
kwb
Explore Scientific ED80
This is a 80mm aperture triplet APO telescope with focal length of 480mm. I'm happy with this guy considering the price.
Squirrel actually eats walnut instead of leaving it somewhere in a hole in my lawn to annoy me
Sparrow puffs up
The reason I bought this one was because I wanted something shorter than my 700mm reflector (Orion Spaceprobe 3). That reflector is quite often too long for what I do, e.g. the full moon image is larger than the 1/1.7" sensor (half moon is OK if I orient the camera appropriately). 480mm is a good focal length for the full-ish moon on Q7, though probably it's still too long for the original Q. Anyway, here's a moon shot (stacked multiple images, then PP in Lightroom):
Moon, 2015/Nov/27
I'm using a Q-C adapter and C-1.25" barrel adapter.
12-10-2015, 06:37 AM   #1027
Hey
Have a chance to grab a wallensak 4.5 and some little Olympus lens of of a small camera about the size of half frame worth getting for the q.. the Schneider lens pics look amazing are you making your own adapters or are they available
---------- Post added 12-10-15 at 06:42 AM ----------
QuoteOriginally posted by GUB Quote
It has taken me a while to work out a way to get some macro extension on my 70mm 110 lens. The lens alone can only focus as close as about 1.2 metres away.
So I bought some Q extension tubes but the shortest one is 10mm and has a too dramatic effect with the camera only able to focus up to about 400mm away.
So I took the metal ends off the longest tube and glued them up to a 40.5 filter ring (glass removed) and this made a nice little 6mm ext tube.
This gave the 70mm an operating range of approx 400 to 700 mm.
I would have to say that even with this mod it is quite a difficult macro lens and is best left for portraiture stuff.
The first 3 images are at f2.8 (wide open) the last 2 with a ringbinder ring stopping it down a little. Apart from the obvious gain of a little more DoF I don't think the 70 responds greatly to being stopped down.
The last image of the red manuka is with the 10mm ext tube. The flower is 12-15mm across.
I want to do this too can you send me some information about the glue you use. Send to terrence5050@yahoo.com thanks thr pics are amazing
12-10-2015, 08:59 AM   #1028
GUB
GUB's Avatar
QuoteOriginally posted by Terrence5050 Quote
I use araldite in these type of modifications. It is strong enough for these light weight lenses.
12-11-2015, 12:15 PM   #1029
pacerr's Avatar
@ Terrace -- Some macro ideas here:
https://www.pentaxforums.com/forums/136-pentax-q/216274-maqro-qlub.html
12-13-2015, 10:30 PM - 2 Likes   #1030
Mothballs's Avatar
Pentax Q with TAIR-3 300mm 4.5
CA in high contrast is controllable, so long as you shoot between f5.6-8 ; Plus it's Green/Violet, so It's not as blindingly obvious as Red/Blue.
Bumped up contrast in Silky. Helps hide the grain.
Edited because i was tired and didn't put TAIR-3 in the title.
PENTAX Q  Photo
12-19-2015, 05:06 AM   #1031
QuoteOriginally posted by Mothballs Quote
nice shot of that Eagle, excellent detail.
01-11-2016, 08:13 PM   #1032
Mothballs's Avatar
Tamron SP 52B 90mm f2.5 on Q
Tamron SP 52B 90mm f2.5 On first Gen Q
Probably one of the best Lenses I own.
01-15-2016, 05:32 PM   #1033
I've got the new Sigma 150-600 on a Nikon mount. It is vastly superior to my 150-500 Sigma on my K3, in terms of sharpness and focusing speed. I might get a Nikon adapter to try on my 'Q' and see if it's better than the 150-500 was.
01-18-2016, 03:07 PM   #1034
Phenix jc's Avatar
QuoteOriginally posted by dc1500 Quote
I bet for a good to very good IQ, Sport or Contemporary. (and same for the Tamron). From 800mm to 3300mm with the little Q when you need it... Just the step beyond 900mm with the APS-C.
Very tempting !
01-18-2016, 03:29 PM   #1035
I have the Contemporary and it seems on a par with the Sports for IQ. Shame they won't do a Pentax K mount. I wonder on the Q if it would be any good for astro shots? Probably too much transverse movement I guess. Moon might be interesting.
200mm, 50mm, adapter, auto, camera, f1.8, f2.8, flickr, focus, hawk, infinity, lens, macro, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shot, shots, smc
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
Ideas on diffusing the onboard flash of the Q? Tonto Pentax Q 28 05-19-2013 11:46 AM
Pentax Q lenses tested by Photozone Mistral75 Pentax Q 9 11-16-2011 12:11 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Could Pentax sell you on the Q if they had better lenses? devorama Pentax Compact Cameras 17 06-29-2011 09:34 PM
All times are GMT -7. The time now is 11:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
