Show Printable Version 232 Likes Search this Thread
02-26-2016, 08:28 PM   #1036
crewl1's Avatar
QuoteOriginally posted by Glorfindelrb Quote
Q7+ DA560 (Pentax Adapter) (2520 equivalent)
100% crop
Looks good. What settings did you use for this shot? Was it stopped down on the adapter? Pentax adapter or another?
02-27-2016, 01:18 AM   #1037
Pentax adapter, f5.6 give the best result with the 560/q7 as the diffraction will impact the shot more than you benefit from stopping down.
03-27-2016, 12:22 PM   #1038
Mothballs's Avatar
Keystone CINE 1/2" f2.5
Fixed focus D-mount.
03-28-2016, 12:32 AM   #1039
second pik is seriously good. "Mothballs" thank u for showing it sir. i have felt that same way alot recently. dont need words to say what it is.
last pik flower bokeh \like alot/
04-22-2016, 12:09 AM - 3 Likes   #1040
kwb
Borg 55 fl
This is a 250mm F/4.5 refractor telescope which is meant for wide field astro photography, but I found that this is a very high quality, light weight, hand-holdable 250mm lens that is very, very sharp when you nail the focus (not easy) with almost no CA due to its fluorite doublet lens. Being a doublet (i.e. just two lense elements), it's actually a pretty bright lens.
I use a BORG EOS adapter and a third party EOS-Q adapter, but they sell BORG K adapter, or even BORG Q adapter if that's what you want.
Giraffe, ISO 200, 1/800 sec, direct sun light. On a monopod.
Squirrel enjoying easy free food, ISO 200, 1/320 sec, in a shade. Handheld.
04-28-2016, 12:34 AM - 3 Likes   #1041
GUB
GUB's Avatar
Microscope Objective lens (Swift 4x) on the Q
A quick jackup with a 4x objective fitted into a hole drilled in an m42 camera body cap and fitted to the Q with my custom made M42 adapter. (Post 630) This adapter ends up shorter than the standard adapter (focusses beyond infinity on a standard lens) and this works well with the microscope objective lens. All images handheld, pped in gimp and not cropped. I think the Q is an ideal sensor for this. On my K01 there is vignetting and softness on the edges.
04-28-2016, 09:01 PM   #1042
Very impressive GUB! Very impressive.
Thanks for sharing.
barondla
04-30-2016, 10:16 AM - 1 Like   #1043
Mothballs's Avatar
Olympus ZUIKO CINE 13mm f1.8
---------- Post added 04-30-16 at 10:23 AM ----------
Olympus 6.5mm f1.8
---------- Post added 04-30-16 at 10:25 AM ----------
Olympus CINE 37mm f1.8
05-03-2016, 08:52 PM   #1044
QuoteOriginally posted by rendition Quote
Steinheil Cassarit 36mm f/2.8 d-mount + pentax Q
Sample Image. This len allows close-focus on Q at tele-focal range
Oh man I just found one of these today for $10 after seeing this picture I can't wait to try it out
06-06-2016, 11:18 PM - 1 Like   #1045
kwb
Canon EF 100mm f/2.8 Macro USM on Q7
Twelve spotted skimmer, on Flickr
I borrowed this lens for a short while for testing, and I think it's good on Q7 (except that you cannot change iris once the lens comes off of Canon camera). This one was shot wide open at f/2.8.
07-22-2016, 11:21 PM   #1046
Transit's Avatar
QuoteOriginally posted by GUB Quote
A quick jackup with a 4x objective fitted into a hole drilled in an m42 camera body cap and fitted to the Q with my custom made M42 adapter. (Post 630) ....
I like succinct descriptions
Frightning ...Hitchcock scene
08-23-2016, 02:01 PM   #1047
coyot3's Avatar
QuoteOriginally posted by kwb Quote
You should put a picture with the lens atached
09-09-2016, 09:26 AM - 1 Like   #1048
Pentax CCTV lens C7528-M 75mm
Won the above lens in an ebay auction.
Brand spanking new so had a little play on both original Q and QS-1...
Neighbour's bug hotel (about 10m away) with Q
and with QS-1
ISO 200 at f5.6
My favourite indoor test subject,,, at about 8 metres
a close up not quite a selfie
Cheers
David
09-09-2016, 11:56 PM   #1049
coyot3's Avatar
QuoteOriginally posted by spinno Quote
and with QS-1
ISO 200 at f5.6
Cheers
David
Mmm that looks nice. You think its a good election for a telepbhoto prime?
09-10-2016, 09:57 AM   #1050
Theoretically 75mm would be equivalent to 300-375 depending on which Q variant you use so I would say yes. The lens is Hoya Pentax but I don't hold that against it...
200mm, 50mm, adapter, auto, camera, f1.8, f2.8, flickr, focus, hawk, infinity, lens, macro, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shot, shots, smc
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
Ideas on diffusing the onboard flash of the Q? Tonto Pentax Q 28 05-19-2013 11:46 AM
Pentax Q lenses tested by Photozone Mistral75 Pentax Q 9 11-16-2011 12:11 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Could Pentax sell you on the Q if they had better lenses? devorama Pentax Compact Cameras 17 06-29-2011 09:34 PM
All times are GMT -7. The time now is 08:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
