Originally posted by sledger OK, so looking at the successes others have had, I bought the adapter (RJ Pentax PK PK-A AF DA lens to Pentax Q adapter with tripod mount aperture ring), so what am I doing wrong?
My pictures are 100% c**p. Hazy, out of focus (even though I enabled focus peaking) and CA like I need 3D glasses to view the pics.
Tried the 30mm SIGMA prime, the 18-250mm DA and the 18-55mm DA. Just rubbish, rubbish results.
The Q always shows AV on the screen, the aperture rind is useful - but it's not helping.
Hand held or tripod, I'm getting truly bad results.. I mean shocking bad..
Someone have a step by step fool proof process to use let's say the 18-250mm with the adapted Q?
Some lenses just don't work well with the Q. The 18-55 isn't good on the Q, at least in my experience. The 18-250 is a great lens, but is also a superzoom and is not likely a good match for the Q. Because of the Q's sensor size, shortcomings with any lens (CA and lack of sharpness for instance) will be much worse on the Q than on a DSLR.
If you have some good primes, you might have better luck with those.
Since you have the adapter with the ring, if you're using a DA lens without an aperture ring, that's where the ring on the adapter comes in. Otherwise when I use a lens with an aperture ring, I turn the adapter ring all the way to the "lock" position & use the ring on the lens to adjust the f-stop.
The sweet spot for most lenses on the Q is f:4 to f:5.6. Stop down further and diffraction cuts down on sharpness.
Even then, you're probably going to need to apply some post tweaking to get rid of CA & get the best result.
Good luck,
Bobbo :-)
