Originally posted by dh4412 attached two pics of these SPD files that show up when i save a q image from the silkypix developer software that comes with the q and i have to use instead of the pentax camera utility, i can save the image now as a regular jpeg, but also this other file shows up too- nothing happens when i try to open it with any software that i have so far including the silkypix developer, won't let me do anything with it.
Ok - I know what that is. When you edit an image in Developer Studio, it is saving the editing parameters in a separate file, and that is what that SPD file is.
I just tried the following myself to help explain what it does - at least this is how I think it works........
I edited a Q file in Developer Studio, and saved it as a jpeg. After saving, I have my edited jpeg plus the SPD file.
Now when I open that same file that I just edited, it will show me the edited file that I just did. If I edit more on the same image, I am editing on top of the original edit.
Now instead, I have opened that same image that I just edited. next go to "file" then choose "load development parameter" - there you can choose any of the development settings that you used for any of the images listed. Let's say you like what you did with image #222.jpg - now you are working on a different image, let's say image #333.jpg. When you have image #333.jpg loaded in the program, and you want to use the same exact editing parameters you used on image #222.jpg, you click on "file", then "load development parameter", then in the list, choose #222.spd". When you do that, all the same edits you did to image #222.jpg will be applied to image #333.jpg automatically.
Confused yet - I think I am.......
But - if you want to get rid of the program saving the development parameter for every image you edit, you can do this:
When you are saving your next image, after you hit the "development" for the image you are working on, you will see this screen:
In the middle of the right side of that window, hit the "setting" button. That will bring you this window:
The upper right of this window is "Option for jpeg/tiff" - the second check box says "Discard Silkypix parameters and image information". Notice I have this box checked in my screen shot. This will stop that separate SPD file from being saved.
Actually I'm glad you brought this up - I have just been deleting those SPD files as I go along. As I was doing this little tutorial, I learned about being able to not save that SPD file myself - just on little check box!
Hope this helps.
