05-20-2013, 05:39 AM   #16
QuoteOriginally posted by kivis Quote
Looking at this: Polaroid PL-108AF Shoe Mount Flash for Pentax at $49.
Polaroid PL-108AF Shoe Mount Flash for Pentax PL-108AF-PE B&H
This is interesting... Not many reviews at all out there on the web but does this really do TTL?
Since Pentax uses pTTL, would it mean that it wouldn't work? I don't see any manual power selection too..
Hmm...
05-20-2013, 01:01 PM   #17
ScooterMaxi Jim's Avatar
The Polaroid and pretty much all of the under $100 pTTL units are sourced from Tumax.
I picked up the Opteka EF-750 which is decently small, has bounce, and works reasonably well on the Q, K20D and K-01. Frankly, I tend to avoid using pre-flash TTL (even when shooting Canon which is more advanced TTL). No choice with the Q - external flash requires pTTL. The flash is not terribly well built (I added velcro to increase tension on the swivel so I could add a reflector system - otherwise it was too loose!). Exposures are particularly good when using a reflector or bounce, but tends to overexpose straight on (which I never use anyways). It is easy to overexpose - it seems you need to be within less than two stops of maximum output to get correct exposure. This probably has as much to do with Pentax flash system touchiness as a problem with the Opteka flash unit. Guide number is 85m (100 ISO) which is plenty for flash card use or low ceiling bounce.
I think I paid $30 at Newegg, which does not have it in stock now; but 47th St. Photo (very reputable) has a kit for $40 with diffuser, full pTTL coiled cord, rechargeable batteries and charger - which is a better deal yet. None of this is heavy duty stuff, but will work OK for occasional use (my need for flash is not extensive - especially when it comes to Pentax pTTL).
05-20-2013, 05:32 PM   #18
kshapero's Avatar
Tried this and returned it.
bounce, camera, flash, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, voltage
A50/1.2 cheap! But there is a problem... bhairavp Pentax SLR Lens Discussion 13 04-06-2013 07:17 AM
There IS a Q Extended Warranty from Pentax! Docrwm Pentax Q 31 12-17-2012 03:42 PM
Q is here, will there also be a K-EVIL? archinaut Photographic Technique 27 06-28-2011 11:47 AM
Is there a cheap light meter for usage with manual lenses? justtakingpics Pentax SLR Lens Discussion 19 04-06-2011 09:29 PM
Is there a cheap "landscape" lens that is better than the 18-55 kit I got with K100D? shaolin95 Pentax SLR Lens Discussion 17 06-13-2009 06:37 AM
All times are GMT -7. The time now is 12:07 PM. | See also: NikonForums.com, part of our network of photo forums!
