Originally posted by GibbyTheMole Anyone ever used a 40.5 to 37mm step down ring to attach video lens attachments to the Q 02 zoom? How much vignetting can I expect?
Hi GibbyTheMole,
I just tried it as I've got a step down to 37mm. There isn't any that I can see throughout the entire zoom range. I only checked it at wide open and looked through the LCD at the sky.
Be careful when adding relatively heavy add-ons to the lenses -- they were designed for very light weight, and are relatively fragile when it comes to hanging weight off the front. The zoom mechanism on the Q zooms is the most susceptible to damage this way as it seems that the helicoils are plastic.
A friend has been experimenting with some pretty heavy add ons with the 06 zoom, and he's told me that the zoom ring has gotten a bit sticky.
I've collected a few of the-best rated of these (all TCs), and when I get the step rings to mount them, I'll post some results.
Scott
