01-06-2013, 12:36 PM   #1
Q making strange noises
My Q has started to make an odd electrical-sounding noise. It sounds almost like there's a mosquito buzzing around inside it, mixed with a sound like radio static. It's loud enough to be audible when holding the camera normally for shooting.
It seems to be connected to the shake-reduction system: it goes away when I turn SR off or remove the lens. SR seems to be working normally. I assume this noise is abnormal, but have any of you had similar noises?
Edit: Ok, I saw a post on the UK forum about a similar noise, and the solution was to set the SR options in the Custom menu to 1 instead of 2, so SR activates only at the moment of capture. But still, I don't recall it being that noisy before.
01-06-2013, 01:06 PM   #2
SR makes noise, so I believe this is normal.
01-06-2013, 01:24 PM   #3
Hi JMeyer,
I think you've found the answer to your question. With SR on full time, there is a constant keening sound coming from the camera. Some people's hearing are probably more sensitive to the frequency than others.
Scott
01-06-2013, 02:44 PM   #4
hnikesch's Avatar
QuoteOriginally posted by snostorm Quote
Hi JMeyer,
Scott
I agree, I keep my SR on always and also hear the sound. If I change to shot only the noise goes away but I find it easier to focus and frame long lenses with it on.
Hans
01-11-2013, 07:05 AM   #5
Erich_H's Avatar
Cross-posted from thread: SR-sounds
Just turn off the full time live view SR and use the Shake Reduction Options Mode1.
This is the last [C] tab in the menu and you are looking for option4. By default SR is Mode2. This EATS battery.
With Mode1 you'll still have SR when you take your pic. The constant sound is off though, you'll only hear it when you
press the shutter release for focusing and/or exposing. Thanks/Erik
camera, mirrorless, noise, noises, pentax q, pentax q10, pentax q7, q10, q7, sr
Unusual SR noises Steve.Ledger Pentax Q 4 12-11-2012 03:47 PM
K-5 Strange noises chromo Pentax K-5 8 12-14-2011 05:03 PM
K5 Noises campdog Pentax K-5 6 03-11-2011 08:37 PM
k10 vs k20 reg noises filorp Pentax DSLR Discussion 12 01-14-2009 02:46 PM
Odd noises fron K10D Billgscott Pentax DSLR Discussion 4 09-09-2008 08:44 AM
All times are GMT -7. The time now is 12:25 PM. | See also: NikonForums.com, part of our network of photo forums!
