01-07-2013, 11:39 AM   #1
hnikesch's Avatar
CCTV 2.5mm CS
One of the CS lenses I received when I ordered a C mount was a 2.5mm and I chose to keep it. I ordered a D to Q adapter from E Bay $12 US and had it drilled out to 1" then glued the lens into the adapter. Mistake #,1 I forgot the flange distance of the D mount (12.29 mm) was slightly closer than the CS mount (12.52 mm) and assumed I could still focus, wrong. I had to beat the lens out of the adapter to break the bond of super glue. Just cosmetic damage. and add a shim, This time I used trial and error to obtain a good distance to achieve infinity focus, cut a shim and glued the lens in.
It seems quite sharp and absolutely a keeper.
Adapter link
D Screw mount (8mm movie lens) to Pentax Q mount adapter on eBay!
I ordered a #EL-2.5mm Fixed aperture f2 C Mount Lens (received CS) Super-Wide Angle from Ellipse Security through Amazon $19.95
So far I like It
Hans
PENTAX Q  Photo
PENTAX Q  Photo
Canon PowerShot S100  Photo
PENTAX Q  Photo
PENTAX Q  Photo
01-07-2013, 11:44 AM   #2
Docrwm's Avatar
Glad you like the outcome. Thanks for letting us know how you did it. What did you use as the spacer for the flange distance?
01-07-2013, 11:49 AM   #3
crewl1's Avatar
Good work Hans - adding it to the reference thread.
01-07-2013, 02:19 PM   #4
hnikesch's Avatar
QuoteOriginally posted by Docrwm Quote
I ended up sliding in a piece of cardboard until the glue set then removed it. Like I said above I tried to focus the lens with the spacer to make sure I got infinity before gluing the lens in place.
Hans
01-08-2013, 07:01 PM   #5
digital029art's Avatar
I wonder if your 2.5mm is a sister model to this fixed focus C mount/2.5 : L025F - Fixed Iris Lens C/CS Mount 2.5mm F:1.6 1/3" | COP, USA, Video Surveillance, CCTV Equipment, Camera, Security Products, Surveillance Equipment, Security Camera, Surveillance Camera
( per this previous thread : https://www.pentaxforums.com/forums/pentax-q/200668-wide-angle-c-mount-lenses.html )
If there was just some easy and cheap way to tap out that 1-32 thread into a D adapter .. I wonder what common Home Depot items also use the same thread??
01-08-2013, 08:49 PM   #6
hnikesch's Avatar
The L025F is what I ordered it's a C Mount I believe but they sent me a 2.5mm CS like the other one on the same page as your link the LN-TL25 - C/CS Mount it turned out to be a CS only. A C mount lens can be adapted to a CS camera with a 5mm spacer but a CS can not be adapted to a C mount camera. I took my D adapter to a machine shop and they did not have a 1-32 tap, that is an extremely fine thread unique mostly to cameras so I had them bore it to a slight press fit to the 1" thread then glued it. The D adapter is only about $16 is plus shipping, I am told by Spysonic that the 2.5mm C Mount is no longer being made???
Hans
adapter, camera, cs, distance, focus, lens, mirrorless, mm, pentax q, pentax q10, pentax q7, q10, q7
Pentax 1/2" CCTV 8-48mm f/1 Lens knightzerox Pentax Q 6 10-16-2011 01:44 PM
Michael Bay Should Sue The Chinese CCTV mikemike General Talk 3 01-28-2011 01:05 PM
Sigma 4.5mm and 10mm f:2.8 Substitute Pentax SLR Lens Discussion 5 09-06-2009 04:37 AM
For Sale - Sold: Nikon 10.5mm f/2.8G ED AF DX ivoire Sold Items 2 07-17-2009 07:43 AM
All times are GMT -7. The time now is 02:18 AM. | See also: NikonForums.com, part of our network of photo forums!
