01-23-2013, 09:13 AM   #16
Saxplayer1004's Avatar
Hiumidity is still a factor as heat index is not only about our ability to cool off via perspiration, but in humid environments the suns rays can be more intense. Similar to how you can sunburn easier on overcast days. The heat index is not necessarily the appropriate term, but with high humidity, the suns radiation can be more intense which would certainly contribute to cameras overheating.
Either way, lots of black plastic and metal with not a whole lot of ability to dissipate heat, then add in electronics in cramped spaces, it's not surprising that it overheated. Good to know, but I'd certainly try to avoid keeping it in situations like that
01-24-2013, 07:38 AM   #17
ChrisJ's Avatar
QuoteOriginally posted by crewl1 Quote
Thanks Chris, I'm going to look into those cables. Any particular monitor you are using?
I'm using one of these which is probably overkill.
Lilliput UK 665GL-70NP/HO/Y 7 inch field monitor with high resolution LCD, HDMI and camera battery slot
It has the advantage of accepting lots of different types of input, focus peaking, exposure warnings etc.
Many LCD TV's have HDMI and AV inputs and larger screens, probably cheaper, but not as portable.
Chris
camera, mirrorless, pentax, pentax q, pentax q10, pentax q7, q10, q7, weather
Adapted lenses tested on the Q : the reference thread crewl1 Pentax Q 1054 11-06-2016 09:22 PM
Fotodiox Q to K with Pentax DA 40mm f/2.8 Lens on Pentax Q SonDa5 Pentax Q 3 12-26-2012 06:29 PM
External flash with adapted lenses baro-nite Pentax Q 24 12-20-2012 07:38 PM
Adapted lens wish list baro-nite Pentax Q 10 12-01-2012 10:58 PM
Filters for your Q - native or adapted? Docrwm Pentax Q 15 11-22-2012 07:30 AM
All times are GMT -7. The time now is 08:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
