On the same night I took the moon with Orion Spaceprobe 3 and Q7 (previous post), I actually took some Jupiter shots. I didn't like that the patch of the sky Jupiter was in was covered by very thin cloud or mist or something, making some halo around the star, but today I thought that this might be a good opportunity for me to test some stacking and PP, two things that I'm new to.
After choosing 27 usable shots, I used RegiStax to stack them, then used darktable (that's raw processing software on Linux) to bump up the exposure of the moons a bit, adjusted the dark level to remove most of the halo, and bumped up the saturation a bit.
This is what I got:
If you look closely, you can see one of the moons on the left bottom, two on the upper right, and another one is on the right edge of Jupiter. Also, if you look very closely, you can see some small structures between the bands of Jupiter.
I'm fairly satisfied with the result. I almost gave up on stacking because it was such a pain, but I'm happy I didn't.
What stacking software do you guys use?
I had to kill RegiStax many times because it became totally unresponsive when I gave it 27 files at once, so I had to divide the images to three groups stacking 9 at a time to make three intermediate stacked images, and stacked these three to have the final result that is an equivalent of 27 shots stacked in one image. But I had to manually crop intermediate images so that Jupiter comes to approximately the same position from image to image, otherwise RegiStax couldn't stuck them. And RegiStax stripped most of EXIF information when saving to tiff. It was really tedious.
I first tried DeepSkyStacker, which seems to be a nice program, but it turns out that it is not suitable for pictures like this one because it needs many stars to align multiple images. I'll use it for maybe Orion shot or something in the future.
On a positive note, post processing was not as bad/cryptic/painful as I feared. I think I might improve over time.
