04-30-2013, 04:17 PM   #76
VisualDarkness's Avatar
QuoteOriginally posted by steve1307 Quote
I think that's the best one so far !
Oh, thank you! I can't believe that though and if I can do this I bet you guys can do much much better, I'm no astrophotographer.
04-30-2013, 07:02 PM   #77
QuoteOriginally posted by VisualDarkness Quote
If almost looks like fog in the air but maybe it's the lens.
Nah, if you want something in the air that's this. https://www.dropbox.com/s/80cpnidpk6pimwp/IMGP2002%20Moon%201.JPG From the first set of attempts, with a fair amount of high cirrus that I had to work around.
Look what I finally found between thin clouds tonight! Sadly blooming due to the weather killed any actual sharpness. Focusing was not that extremely hard due to me being able to see the shape of the rings when zoomed in.
Oooooh, nice. Can't wait until I can aspire to that.
04-30-2013, 07:17 PM   #78
ivoire's Avatar
Pentax Q + Kenko 1.5x PZAF + Pentax DA* 300mm F4
Great capture! The DA 300 looks like the best fit for Q use
04-30-2013, 08:30 PM   #79
QuoteOriginally posted by Travis Butler Quote
Yeah, that's some thick air passage! I had cirrus on both my moon shot and the Saturn one but both were at the edge of the clouds. Clear nights seems to be rare now.
If I could achieve that, anybody can. You just need the minimum equipment, good eyes to set focus right and most of all decent weather. Too bad you can't control the last one.
QuoteOriginally posted by ivoire Quote
It works well on the Q. The only beef I have with the lens for this use is that the clutch has that small play which maker it harder to get small movements with the focus ring.
04-30-2013, 08:36 PM   #80
Yeah... today, 'twas in the mid-80s F, sunny, light clouds. Tomorrow, temp drops 10 degrees F, chance of thunderstorms. Day after tomorrow, 60% chance of precipitation, rain mixed with snow.
I thought it was supposed to be spring in my part of the world? Ah, well, if it does snow, might be an interesting photo opportunity...
05-02-2013, 06:49 PM   #81
jimr-pdx's Avatar
So either I missed it or it hasn't come up yet - has anyone crafted a Q-to-1.25" coupling?
The Q has such a short registry distance that my focuser might work without modification. I have a nice 850mm f/5.6 (my 6" scope) that I'd like to stick beneath my Q... no clock drive but it would be fun to try. If nothing else it could make a nice screen for 2-eye viewing of what the telescope sees.. and oh yes, the coupling would work just as well on my 2-meter f/4.5!
I've ordered a C-adapter and a couple of blank body caps, for the next time I feel lucky with power tools!
05-04-2013, 05:48 AM   #82
QuoteOriginally posted by jimr-pdx Quote
Easy to do with off the shelf parts
A Q to C mount adapter, and a C mount to 1.125" just screw together
[IMG] [/IMG]
Here are the links for eBay UK
C mount 16mm Cine Film Lens to Pentax Q P/Q PQ mount adapter | eBay
C Mount Adapter, Adaptor from 1.25" to C-Mount Thread, TS1-C Connector, New | eBay
Similar will be available from eBay where you are.
Chris
05-24-2013, 03:23 PM   #83
ElvisQ's Avatar
I have $100 to buy a lens to shoot the moon. What lens do you recomend?
05-24-2013, 07:39 PM   #84
Tough question ElvisQ. I would say used and probably orphan lens mount. Got a good deal on a Canon FL mount lens. It is 200mm f3.5. Closed down to f5.6 it is pretty sharp and the fringing is well controlled. I posted a few shots in the sticky adapted lens thread. Canon FD mount lenses mostly fit mirrorless digital cameras these days. This makes them cheaper. Minus is having to buy Q to FD adapter.
thanks
barondla
05-24-2013, 09:34 PM   #85
QuoteOriginally posted by ElvisQ Quote
Like barondla said an orphaned mount lens would be cheap. I would say a 300m f4 ish lens and may be a teleconverter too. I am assuming you already have a good tripod.
05-25-2013, 02:43 PM   #86
ElvisQ's Avatar
Yes, Canon FD or Pentax M42 are orphaned mounts.
What is the better option for $100?
A high-quality 135mm 2.8 with TCx2 or a cheap 300mm 5.6?
05-25-2013, 07:05 PM   #87
M42 isn't orphaned as bad as Canon FD. All Pentax K can use M42 with an adapter. There are lots of other cams that can use M42 including Canon.
I would go for 300mm vs 135 + 2X. Better odds of victory. Can you try either lens before buying? What are the brands?
thanks
barondla
05-25-2013, 08:00 PM   #88
ivoire's Avatar
The tamron 60-300mm adaptall is a very sharp lens and can be had for under $100
Review:
https://www.pentaxforums.com/userreviews/tamron-adaptall-2-sp-60-300mm-f-3-8-5-4-23a.html
http://www.ebay.com/itm/Tamron-60-300mm-f3-8-SP-manual-focus-Macro-adaptall-...item3f253f5a49
http://www.ebay.com/itm/PENTAX-TAMRON-ADAPTALL-2-K-MOUNT-ADAPTER-IMMACULATE-...item35c7c0107f
05-28-2013, 03:39 PM   #89
ivoire's Avatar
"Super Moon" June 23rd
Is biggest, closest full moon on June 23, 2013 a supermoon? | Tonight | EarthSky
05-28-2013, 03:49 PM   #90
I like how Sweden is right in the middle of the day part of the map.
astro-q10, camera, filter, galaxies, galaxy, h-alpha, mirrorless, nebulae, pentax q, pentax q10, pentax q7, q-s1, q10, q7, sky, smc, whirlpool
For the Astro Shooters wildlifephotog Photographic Technique 2 10-15-2012 10:41 AM
Enabling astro tracking without the O-GPS1 atekant Pentax K-5 & K-5 II 2 04-06-2012 10:42 PM
Joined the Q Club. Dr_who Pentax Q 9 04-04-2012 01:29 AM
Q for the Q & DSLR users jezza323 Pentax Q 6 02-05-2012 09:13 AM
Astro-Photo Unregistered User Troubleshooting and Beginner Help 9 02-24-2011 08:47 AM
All times are GMT -7. The time now is 09:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
