01-12-2014, 10:27 AM   #106
Adorama Camera Representative
Helen Oster's Avatar
QuoteOriginally posted by jezza323 Quote
Adorama want almost half the cost of the adapter for shipping........
If you email me directly: Helen@adorama.com we can look at whether there may be any more economical shipping methods available.
01-17-2014, 04:40 AM   #107
I finally managed to get my Tair 3-PhS focusing to infinity, thank god...
So I immediately put it on a 2x TC and the Q adapter of course 300mm lens @ f8 + 2x TC + Pentax Q = 3300mm f16 equivalent, the moon was larger than a full frame, this is 7 shots quickly stitched in Autopano...
01-17-2014, 05:58 AM   #108
Sandy Hancock's Avatar
My best moon shot with the Q and DA*300. Yet to try with the Q7.
Q Moon
01-26-2014, 05:26 AM - 1 Like   #109
I finally got a clear enough night since finishing off my barn door tracker to try it out, since its a little small and flimsy I thought a good first test would be the Q+01 lens since its light, and I can shoot 30' exposures. I didnt try aligning by sight, I just used my phone as a compass for direction (South), location (to get the latitude) and level to set the angle to my current latitude. When using a longer lens I plan to set alignment like this followed by a little bit more drift alignment.
It works! This is a 100% of the WORST exposure (tracking wise) @ 30 secs
And this is the BEST @ 30 secs
After this I toned it down to 15 secs but higher ISO for 13 shots, before the clouds came over
I then quickly stacked what I had (+4 dark frames) in DeepSkyStacker for this result (4x 30' ISO 125 f2.8, 13x 15' ISO 200 f2.8, 4x DARK 15' ISO 200). Only a small portion of the frame here...
And this is what it looks like....
4x AA into ebay $1.50 buck regulator into ebay $7 3v 3rpm motor + some 48p pinion gears, some bent M6 threaded rod and a couple more bits to put it all together...
Some adjustments to be made with the gearing so I can run a bit more voltage & higher torque and the rod radius could use some tidying as well. Once I improve tracking a little more the next test will probably be the 30mm f1.4 on the Q (~165mm equiv) before I move onto astro with the K-5 & the 70-200mm or Tair 300mm and take the setup travelling out of the backyard to where the skies are darker!
03-01-2014, 07:10 AM   #110
hello, i want to buy a Q, i also have a telescope, a Celestron nexstar 4se, what i want to know is if i put the Q in the prime focus with a Q to T adapter like the kipon one (Amazon.com: Kipon T2 Mount Lens to Pentax Q Camera Body Adapter: Camera & Photo ) i'll be able to do long exposures to take pictures from M42 or other bright deep sky objects?
03-01-2014, 12:42 PM   #111
QuoteOriginally posted by yuhuyu Quote
The maximum shutter length when using adapted lenses on the Q is only 2 secs. However if you use the Pentax K mount to Q mount adapter you can do long exposures. This is because the Q body has no shutter. Shutters are part of the Q lenses, and in the Pentax adapter. You would then need a T mount to K adapter for adapting the adapter to your scope!
Hope this helps a little
03-05-2014, 10:17 AM   #112
look what i've found on the youtube :O
i was searching about de q and astrophotography, and i found this ! is awesome you can find more videos that've been done with the Q in that channel !
03-07-2014, 04:26 AM - 1 Like   #113
News lens, so new moon shot! :P
Sigma 150-500mm OS HSM @ 500mm ~f11 or maybe f16, hard to tell, ISO 400, 1/60 on original Q, totally uncropped
03-10-2014, 04:50 PM   #114
here's one form the q , qk adapter and sigma 500mm
03-10-2014, 04:53 PM   #115
baro-nite's Avatar
QuoteOriginally posted by pearsaab Quote
Tough to squeeze that into the frame! Nice one.
03-10-2014, 04:57 PM   #116
thanks...now that you mention it it was
03-10-2014, 05:08 PM   #117
VisualDarkness's Avatar
The moon must have speeded on the LCD :O
03-12-2014, 08:12 AM   #118
baro-nite's Avatar
QuoteOriginally posted by NoRules Quote
now I get prime focus on the Coronado
Thanks for the detailed post -- valuable info. Can't see an image, so please retry -- I'd love to see it.
03-12-2014, 08:24 AM   #119
The Sun, Second try.
QuoteOriginally posted by baro-nite Quote
Hi, fellow Pentaxians and astro photographers!
Long story short: I got my hands on a used Coronado 60 solar scope this winter. Problem was that a DSLR could not focus in prime focus on the scope. I had to use a Barlow lens to get infinity focus. That degraded the image somewhat. I then got the idea to try a Pentax Q, because of the very short flange-to-sensor distance. Problem no. 2 arose very soon after I got the Q7 in the mail. To get a T-mount adapter, I had to use a DSLR adapter first. Today I solved the problem. I got a D-mount adapter in the mail, and I glued the thread-ring of a standard T-mount adapter to it via a thin metal sheet. Anyways, now I get prime focus on the Coronado. Resolution is way above anything I have encountered. The Q system is fantastic for solar system objects. This image of the sun is just one exposure. No stacking. Have to practice my PP skills. Very difficult subject matter! NB! There is something wrong with uploading the image, it gets down-scaled from 400 to 68kb. It looks terrible. I'll just post it anyway. Sorry about that.
PENTAX Q7  Photo
03-12-2014, 09:20 AM   #120
baro-nite's Avatar
Have a look here:
https://www.pentaxforums.com/forums/12-post-your-photos/6-how-upload-photos-b...tart-here.html
For attached images you need to keep them to 1280x800 or smaller to avoid automatic re-sizing.
astro-q10, camera, filter, galaxies, galaxy, h-alpha, mirrorless, nebulae, pentax q, pentax q10, pentax q7, q-s1, q10, q7, sky, smc, whirlpool
For the Astro Shooters wildlifephotog Photographic Technique 2 10-15-2012 10:41 AM
Enabling astro tracking without the O-GPS1 atekant Pentax K-5 2 04-06-2012 10:42 PM
Joined the Q Club. Dr_who Pentax Q 9 04-04-2012 01:29 AM
Q for the Q & DSLR users jezza323 Pentax Q 6 02-05-2012 09:13 AM
Astro-Photo Unregistered User Troubleshooting and Beginner Help 9 02-24-2011 08:47 AM
All times are GMT -7. The time now is 10:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
