03-12-2014, 10:06 AM - 3 Likes   #121
QuoteOriginally posted by baro-nite Quote
Have a look here:
https://www.pentaxforums.com/forums/12-post-your-photos/6-how-upload-photos-b...tart-here.html
For attached images you need to keep them to 1280x800 or smaller to avoid automatic re-sizing.
I know. There is something strange with the file. Have tried another computer, different browsers. I could not upload to DPreview either. Well here is a link to the image as it should be.
Edit: Link or URL removed. I found the fault. The deep reds of the image messed it up. I converted the image to yellowish. I think its ok now. Not red H-alpha, but still ...
03-12-2014, 08:37 PM   #122
Super capture. Is this image cropped or is this the full field of view? Are there different settngs or filters on the Coronado? If so would love to see what they do. A Q sun video would be a thing of beauty.
thanks for sharing
barondla
03-12-2014, 10:59 PM   #123
Hi Barondla,
Thanks! This is a slightly cropped image. The Coronados are 400mm lenses with different f.stop. The 60 has an f.stop at 6.7 (the 40 is at f.10, and mainly good for viewing, but I'll bet the original Q could do beautiful stuff on it). The filter in front costs $900, and there is a set screw that can tilt the angle of the filter unit, depending on if you want to see protuberances or surface detail. The Coronados are build either for Calsium K-line or Hydrogen-alpha spectrum. Mine is H-a. A video will never be made. Sorry. I'm not that kind of guy
03-13-2014, 10:01 AM   #124
baro-nite's Avatar
Impressive work -- looking forward to seeing more. TFS.
03-14-2014, 06:44 AM   #125
Next attempt
Allrighty then. I did one more yesterday. Tried to push a little harder. Still some wrinkles to iron out though. Q7+ DIY T-mount adapter+ Coronado 60, Prime focus.
PENTAX Q7  Photo
04-02-2014, 10:42 AM   #126
Hello everyone.
crewl1 recommended me too look into this thread given my plans to buy and combine a Q with a Apo ED telescope (Equinox-120 PRO OTA) for wildlife and astro photography.
I wounder. does anyone participating in this thread have any experience or knowledge regarding on how well the Qs (the Q10 and the Q7 respectively) performs with such a scope.
Crewl1 suggested that the Q7 might yield better results despite having less crop-factor, and his photos would seem to give his claim weight (https://www.pentaxforums.com/forums/136-pentax-q/173602-reach-q-images-63.html#post2750571).
Anyone have any information or thought on the matter?
04-02-2014, 02:37 PM   #127
Q7 is definitely superior in image quality. Google tells me your scope is 900mm f7.5? f7.5 is into diffraction on the Q series but it should be acceptable. You are going to need an absolutely rock steady mount though. It will be roughly 4500-5000mm equivalent in 35mm format terms on the Q7/Q10 & Q. Also, unless you use the official Pentax Q > K adapter as part of your fitting the Q to the scope, you will be limited to 2sec exposures max, and jello effect below 1/13sec min. Something to consider.
04-03-2014, 07:04 AM   #128
QuoteOriginally posted by jezza323 Quote
Thank you for your reply jezza323. I appreciate it.
It is good that the info you and crewl1 provided has brought my attention to the concept of diffraction, as I was only vaguely familiar with it before your reply.
Its interesting with all the variables. Pixel density (pixels on target), pixel size (affect by f/stop diffraction) lens quality and so on.
This got me thinking, Does anyone know of a calculator or collection of charts showing the relation between these factors?
Because what you really want is some kind of standard of sharpness on a 100% crop. For example, using a Q7, it might turn out that it would be better to go for a 500mm f6.0 than a 900mm 7.5 if the former had a resolution that would allow cropping past the reach of the later (900 mm f 7.5) with details preserved. For what is 12 mega-pixels worth if resolution is basically 2 mp due to heavy diffraction.
Perhaps it is even worth to consider a mirror telescope given their longer reach and aperture relative to price.
There must be some way do find the where the sweet spot is, at last roughly.
04-03-2014, 08:02 AM   #129
baro-nite's Avatar
QuoteOriginally posted by Expeditioneer Quote
So much depends on the particular lens involved, there's no substitute for testing the actual lens on the actual camera. But as a general guide, if a lens's sharpest aperture is slower than f/5.6, f/5.6 is probably the sharpest aperture on the Q -- the best compromise between lens sharpness and differaction. And that describes the vast majority of 135-format lenses.
04-14-2014, 07:43 PM   #130
someone taking pictures of today's lunar eclipse with the Q? !
04-14-2014, 07:50 PM   #131
I will give it a go if my son allows me to!
Sigma 150-500mm + Q + tripod
04-14-2014, 08:08 PM   #132
i'll try with my telescope and the Q, the focal lenght is 1325 with the crop factor it sucks cause the moon looks so close T_T
04-14-2014, 08:43 PM   #133
The moon was larger than the frame on the original Q @ 600mm (300mm w 2x TC)
Might not be too bright though, since it will be in eclipse... see how it goes I suppose
04-15-2014, 01:20 AM   #134
MarinatedHerring's Avatar
No lunar eclipse photos yet?
Well, I'm not really good at astrophotography but here is my impatient attempt
04-15-2014, 01:22 AM   #135
crewl1's Avatar
These are cross posted from the blood moon thread.
Q7 + DA*300
astro-q10, camera, filter, galaxies, galaxy, h-alpha, mirrorless, nebulae, pentax q, pentax q10, pentax q7, q-s1, q10, q7, sky, smc, whirlpool
For the Astro Shooters wildlifephotog Photographic Technique 2 10-15-2012 10:41 AM
Enabling astro tracking without the O-GPS1 atekant Pentax K-5 2 04-06-2012 10:42 PM
Joined the Q Club. Dr_who Pentax Q 9 04-04-2012 01:29 AM
Q for the Q & DSLR users jezza323 Pentax Q 6 02-05-2012 09:13 AM
Astro-Photo Unregistered User Troubleshooting and Beginner Help 9 02-24-2011 08:47 AM
All times are GMT -7. The time now is 08:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
